Having the timing belt & water pump done. What else should I do with it?
So I'm at 100k, and I'm having the timing belt and water pump done. Is there anything else that I should have the Tech do while he's doing the belt and pump?
Well...it's kinda fast...
As far as routine maintenance, I would also replace the idler and tensioner pulleys, auto tensioner (if it has never been replaced), tranny fluid, clean TB. For performance, might as well upgrade to a UR pulley since the belts and OEM crank pulley need to be removed anyway.
Maintenance schedule is here:
https://acurazine.com/forums/showthread.php?t=178269
Might want to have them change the brake fluid, and some other things if they haven't been done....
asahrts
09-04-2015 05:55 PM
