have i installed wroung plugs
i got my plugs from spark plugs .com they said these were the plugs for type s bkr6e1x-11(3764) ngk.
What happens now do i pull them out or leave them in will i damage the engine?
Happy CL-S Pilot
More info about "Projected Spark Plug":
Source: http://www.picknowl.com.au/homepage.../tech/spark.htm
Therefore, I understand that the "Projected NGK Irdium Plug" is the High performance version
Projected Core Nose: This type sticks the spark 1/8" into the combustion chamber. This helps prevent low speed and cold fouling and also gets cooled by the incoming charge at high speed. It is difficult to build a projected plug in very cold heat ranges however, because of the long ground wire, which is typically the hottest part of the plug. To a very limited degree, this plug behaves as though the ignition were more advanced, because it places the flame more centrally in the chamber.
cycdaniel
12-17-2019 10:58 AM
