Guys, i need help to order the correct part!
Old Jul 25, 2010 | 03:01 PM
CivicB18B1's Avatar
Last month, i went to www.rockauto.com to order the 2 upper front ball joint Moog part # K90336 in the section Suspension>ball joint
So i took an appointment with my mechanic to change the 2 upper ball joints...
He called me during the day to tell me that he could not change the ball joint because i need to buy the control arm with the ball joint pressed in.
Like in this picture from acuraoemparts.com:
#4or5
So my question is, does Moog makes the upper control arm with the ball joint pressed in?
I want to buy moog because its better then oem...
Thanks!
Old Jul 25, 2010 | 03:26 PM
victorvu's Avatar
your mechanic is wrong tell him to press out the ball joint and press the new one in if he doesnt have a press he wont be able to do it
Old Jul 25, 2010 | 06:16 PM
civicdrivr's Avatar
Old Jul 25, 2010 | 06:45 PM
YeuEmMaiMai's Avatar
get a new mechanic. before honda stated you had to replace the entire control arm but then they changed to a press out old and press in new joint
Old Jul 25, 2010 | 08:54 PM
Rajca's Avatar
wham bam thank you ma'am
use a BFH. worked for my lower ball joints
Old Jul 26, 2010 | 04:52 AM
RooEng's Avatar
You think your mechanic would be offended if you told him to watch an install video? http://spc-tv.com/install/pass-car/3...ll-joints.html
You could do it yourself if you can get loaner tools from a parts store.
I did mine. I didn't have the right tools so I used a gear puller to pop the ball joint off the spindle, removed the control arm bolts, #12 in your pic, removed the arm, supported the arm with 2 blocks of wood and put a big socket on the ball joint and beat on it with a BFH. Installation is the reversal of removal.
Old Jul 26, 2010 | 08:53 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Jul 26, 2010 | 10:25 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
The upper ball joints are very easy even with the arm on the car.
The lowers,is a whole differn't story for me.
The rented tool's receiving cups would not sit flat so I could not use the rented tool for that.
I just took off the whole spindle and had the shop I always go to do them.
They did my lowers and installed my wheel bearings for 20 bucks.
felt like x-mas that day.
csmeance
Jan 7, 2026 06:25 PM
saberlove
Mar 11, 2021 09:29 AM
Nicho863
Sep 3, 2015 09:16 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
