GUMOUT...should I use it?
Brand name fuels have enough mild detergents in it to keep your fuel system fairly clean if used regularly. That's what really seperates one gas company from another - the fuel additives/formulations. All gas pretty much comes from the same refineries.
I've read fuel injector cleaner can degrade seals due to it's potency. Unless you are experiencing heavy bog under load or roughness that you believe is due to bad spray pattern, I wouldn't use it.
But it's ultimately up to you.
-Vlad
-Vlad
