ground control coil overs?
Old Feb 9, 2003 | 04:58 PM
AkuraCLS's Avatar
ALi G in the House!
does anyone have these? if you do, how's the ride? how hard is it to adjust? how much u get em for? did you change ur shocks too?
thnx!
-Sam
Old Feb 9, 2003 | 05:19 PM
mattg's Avatar
IBsoopa
my friend (acura technition) has a 03 6mt w/ koni's and gc's, dropped on 3pc. 19's.
he loves the setup, says it rides like a caddy, no creaks or noises. they are easy to adjust too.
i would recommend against using them w/ stock shocks, you need the koni's.
Old Feb 9, 2003 | 06:16 PM
AkuraCLS's Avatar
ALi G in the House!
do you know how hard it is to adjust them? like what is the process....
Old Feb 9, 2003 | 07:14 PM
soopa's Avatar
The Creator
the ground controls are RIDICULOUSLY EASY to adjust.
you just loosen the spring seat with an allen wrench... and turn to your desired height.
however... i've just removed mine.
heres the problems:
- can't be used with stock shocks more then ~2-3 months. they will DESTROY them.
- super super super soft... so unless you run your shocks super stiff... you will bottom out like mad.
HOWEVER>> I have heard a buzz that Ground Control is making a spring better suited to our car... but you have to call them to get it.
Old Feb 9, 2003 | 07:16 PM
soopa's Avatar
The Creator
oh btw... they do make a TON of noise....
my ground controls never stopped making noises. it was always one noise or the other...
thats mainly why i ditched them.
the spring isn't the appropriate width for our isolators... so you need to either get custom isolators or deal with noise & the spring hitting your frame. heh.
they also squeek alot... but as long as you lube them everytime you jack your car or adjust the height... you can squelch the squeeks.
but i couldnt find a way to stop the clunking from coming back...
Old Feb 9, 2003 | 07:43 PM
joedokes28's Avatar
Originally posted by mattg
IBsoopa
You can't tell us about something that cool and not post a pic.
Old Feb 9, 2003 | 09:27 PM
AkuraCLS's Avatar
ALi G in the House!
lemme ask you this then..what about the vspec ver 2 coilovers? anyone know how those ride? if they make noise, and how hard they are to adjust?
thanks again!!!
Old Feb 9, 2003 | 11:02 PM
peiqinglong's Avatar
Get Teins or Endless Zeal
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
BoricuaTL
Apr 8, 2016 01:08 PM
PortlandRL
Sep 14, 2015 12:01 PM
