Grinding Noise In 2nd Gear!!!!!!
The last few weeks I've been noticing a grinding noise when I shift from 1st to 2nd, but only when I shift hard. I hope its nothing to worry about, because I don't seem to be having any other problems in all other gears. Like I said, it's only when I shift hard and it only happens from 1st to 2nd. Anyone know what it could be from, or if it's anything serious that I should worry about?!!
EVERYTHING IS FOR SALE!
Originally Posted by typeS6S
i think it happens to all of us 6 speeders. I changed my transmission oil with the new honda stuff and its all gone.. At least for now
And di you go to acura, honda or checkers or something to get it. Thanks
I've never had any grinding on my stock 6spd. 5yrs/65K miles so far...
I did have some notchiness on the 1-2 shift when the car was new during the winter (cold fluid), but that went away after the 1st year...
I only get grinding when I miss a shift, and let the clutch out before I'm in (2nd) gear... which might happen once a year...
Trolling Canuckistan
I get a bit of notchiness if I'm shifting mildly from 1st to 2nd, typically in the 3000-3500 range, but it doesn't happen consistently. It never happens if I shift past 4K.
When it happens to me, it only seems to occur if I rev the engine slowly and shift in the 3.5-4k range. If I get into the gas more aggressively or shift above 4k, it doesn't seem to happen and it's definitely not a grind it's just notchy.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
