Green/Silver Wire is what?
Old May 12, 2003 | 09:10 PM
Lester_leaps_in's Avatar
Semper Fi
Hard-wired my v1 this week-end. Easy enough to do.
I tapped into a green/silver wire near the driver's side fuse box for power. It has no power until I turn the key on. Then it has 12 volts, so I thought it would be a good choice, and, sure enough, my v1 works fine.
Here's what puzzles me. When I turn the key off, the power stays on until I open the door. Then it's off until the next time I turn the key on.
So, anyone know what the green/silver wire is? And, can someone suggest a different wire in the same location that would be a better choice?
I mounted my remote on the steering column, by the way. Works fine for me. With my seat and steering column adjusted the way I like'em, I can see everything easily. Being short has it's advantages, I guess.
Anyway, what's up with that green/silver wire?
Old May 12, 2003 | 09:27 PM
Six Shifter's Avatar
an adult perspective
If I'm not mistaken, the system is wired in such a way that you can operate your windows/moonroof for a short period of time after the ignition key is turned off .... or until you open the door. Sounds like you may have tapped into this circuit. Briefly looked in the manual, and I see some Green/White wires, but no Green/Silver - but I was looking at the '03 M/T wiring.
Old May 12, 2003 | 11:57 PM
AztecRol's Avatar
The Screeching Toyo's
In my 01 Helms, it shows GRN/WHT as the moon roof circuit, which is on the 10 min delay that Y2K3CL-S mentioned. I did NOT see any GRN/SLVR wires.
Hope this helps!!!
Old May 13, 2003 | 06:15 AM
Semper Fi
Thanks for your responses.
Maybe it was green/white. I don't do colors well. When I was a kid, my parents could only afford to get me the box of 8 crayolas, not the box of 64. So, my color sense is not properly developed.
I'll take another look this week end.
Anyway, I wish I'd picked another wire.
Thanks, again.
Old May 13, 2003 | 04:31 PM
Unless somebody has some reason to the contrary, can't see what harm using that wire would cause ... unless the operation of your windows/moonroof impact the functionality of the V1 or vice versa ... and this way you'd always know that it has been shut down each/every time you leave the car.
Old May 13, 2003 | 06:28 PM
Jens H.'s Avatar
retired
Look on the connector side of the fuse box there are several unused single point connections .One of them is power with ign on .Although there is no harm in tapping into that circuit mentioned why risk it.Jens
Old May 13, 2003 | 11:06 PM
Juker008's Avatar
TRELOS
Juker008
Old May 13, 2003 | 11:07 PM
Juker008's Avatar
TRELOS
Hope this helps!!!
Where, what page?
Juker008
Old May 14, 2003 | 02:44 AM
AztecRol's Avatar
Originally posted by Juker008
Where, what page?
In my Helms, it is page 22-64. It has the Passenger's Under Dash Fuse/Relay Box chart. It lists all the fuse numbers, how many amps, wire color and what each one is used for. I realize this is the passenger side, but it is the only Grn wire that I could find that had a light colored stripe. The only other Grn wire that I found with a stripe had a black stripe!!
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
