Got my alignment done - results
Old Aug 2, 2005 | 01:27 PM
Lord Helmet's Avatar
I'm here in spirit...
Can anyone read these things? This was done after installing my H&R 51858's. Does this look ok to you guys?
Old Aug 2, 2005 | 03:01 PM
Bobbydoedoe's Avatar
I'm Cool
is this before the alginment or after?
Old Aug 2, 2005 | 03:08 PM
The top half of the sheet is before and the bottom is the aftermath.
Old Aug 2, 2005 | 03:14 PM
I'm Cool
o hahah, i guess i'm gettign old. Well for my rear camber, their both off by .1 degrees, and the mechanic told me that i don't need an alignment kit, unless ur bill gates
Old Aug 2, 2005 | 04:25 PM
NiteQwill's Avatar
Adventurist.
https://acurazine.com/forums/showthr...ight=alignment
Old Aug 2, 2005 | 04:31 PM
Pure Adrenaline's Avatar
Dragging knees in
That is a nice print-out chart. Belle Tire around here gives a print-out with just numbers basically.
But yeah, it looks like it's mostly within spec, and they adjusted the front caster a little bit which is the angel of the suspension in relation to the pavement. Before the alignment, it was leaning back, so to say, but now it's more straight up. Toe was kind of out of spec, but not too horribly. But it's adjusted to within spec now, too, so nothing to worry.
The only thing is that the rear camber is still kind of off, but -1.x degrees isn't THAT bad. In fact, it will help cornering and that much negative camber (with proper toe) won't hurt the tires that badly, either.
If it were approaching -2.x degrees, then you might have needed a camber kit. But you should be fine.
How much was it? Just curious.
Old Aug 2, 2005 | 04:39 PM
mclarenf3387's Avatar
You mean toe, which is the relationship between the distance between the fronts of the wheels and the backs.
Caster is not adjustable on our cars without aftermarket parts which are non-existant.
Old Aug 2, 2005 | 04:43 PM
I paid $70 for it.
Old Aug 2, 2005 | 06:58 PM
bigguyonbike's Avatar
13.2 @ 104.76mph
that looks real good. your tires will wear evenly.
Old Aug 2, 2005 | 07:41 PM
cls-gator's Avatar
That printout is great! What was the name of the shop that did the alignment and provided the printout for you?
I am finally putting on my Tanabe springs and Tokico HP's in a couple weeks and I want to get an alignment afterwards and that printout is exactly what an idiot like me needs to understand what happened, if anything.
Old Aug 2, 2005 | 07:59 PM
Joe5.0's Avatar
TQ > MPG
Thats a nice printout, and that rear camber isnt anything to really worry about. Just rotate the tires every 3k and they'll wear perfectly fine. Negative camber helps with cornering due to having more contact patch when the tire rolls over in corners.
Old Aug 2, 2005 | 08:53 PM
Dragging knees in
Dang it, yeah, I mixed it up. I looked at the wrong sections.
Old Aug 3, 2005 | 07:49 AM
Thanks for all the input. After driving the car at high speed for several miles last night, I noticed it still pulls to the right a bit. Should I be concerned? I thought it's supposed to track straight down the road. Should I take it back to 'em?
BTW, Big "O" Tires around the corner from my office did the job. Nice guys but I question their work sometimes.
Old Aug 3, 2005 | 08:10 AM
fuzzy02CLS's Avatar
If it pulls to the right, swap the front tires. If it still pulls right it's the car. If the pull moves to the left it's the tire/rim.
Old Aug 3, 2005 | 08:18 AM
It's the car?? As in, my car is jacked up or my car's alignment is still off?
Old Aug 3, 2005 | 10:05 AM
fuzzy02CLS's Avatar
The alighment can't be off if that printout is correct. Swap the fronts see what happens.
Old Aug 4, 2005 | 04:31 PM
BoostMotives's Avatar
have them redo it a gain. they shuoldstand behind there work if it is pulling to the right like you say. no car is ever going to be 100% straight .. maybe 99.8% straight.
as long as your withing i believe 1 degree on each side your fine ? someone corerct me if im wrong ?
Old Aug 4, 2005 | 06:07 PM
Tires could be out of balance. DO what fuzzy said first and see if they need to be balanced.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Tribalheads
Sep 29, 2015 03:24 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
