Got code :(
Got code :(
CEL came on after header install. Took it to Advance Auto and it came out with P0141, 'Heater sensor malfunction." I did a search and the second 02 sensor was mentioned, are they related?
Hmm, I rechecked the first sensor this morning and it was in all the way. The secondary sensor was never removed...it is dark outside, but I am going to try and see if it came lose somehow.
the secondary o2 sensor is in the middle of the cat. shouldnt have been touched from a header install, but they may have knocked the wiring. worst case scenario is replacing the o2 sensor which is about $80-100 and 5 minutes of your time.
lol it's all good. Thanks guys, the secondary o2 sensor wasn't removed, but it was a little loose. I went under and noticed there was some play in the wire, I reached up and pushed the clip in all the way. I reconnected the fuse and the battery and the CEL went off.
I am going to redo the install using lock washers to make sure everything is tight.
Sorry to raise the dead post here, but I've had the CEL on since I had my XS Headers put on in FEB '07. I know, I know... I'm terrible but I had my reasons.
This weekend I finally put on a new O2 sensor but lo and behold I still had my CEL on. I borrowed my buddy's OBDII scanner and pulled the famous P0141 even with the new sensor.
Can you guys give me a basic rundown of connections and things to check? I am not super mechanically inclined, so use layman's terms here please. Also I never touched the second O2 sensor, should I still check connections?
Thanks in advance!
Thanks in advance!
Jamus22
Jun 11, 2023 10:08 AM
