good or bad???
Old Apr 25, 2007 | 12:56 PM
misterdannyboy's Avatar
good or bad???
acura is changing my transmission ..but they found a few problems
front rotors warped..rear brake pads needs to be changed..engine mounts needs replacement...and change of transmission oil-- all for a little over 1000
good or bad deal?
if bad ... r there any suggestions
i was thinking of getting aftermarket rotors and pads (brembos)????
changing the transmission oil myself..??
any help would be nice thanks..
Old Apr 25, 2007 | 01:00 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Tranny fluid is changed when the tranny is changed. I wouldn't let 'em change rotors/pads, though. Go aftermarket.
Old Apr 25, 2007 | 01:04 PM
SuperTrooper169's Avatar
In the Mid-South meow
Oh, btw gapping46and2, I'm stealing your screen name for my specialized plates. Hope you don't mind.
Old Apr 25, 2007 | 01:14 PM
they said about 200 to change the fluid..300 for engine mounts..500 for front rotors and back pads..
do u know where i can get aftermarket for a good price..?
Old Apr 25, 2007 | 01:20 PM
Hmm, changing the fluid is a given when changing the transmision, doesn't seem right they're trying to charge you for that. Weird.
As far as aftermarket rotors, there's tons of different companies making slotted or drilled rotors for our cars. Rotora seems to be very popular, as well as Brembo. I personally have the R1 Concepts rotors and they're great and pretty cheap.
Old Apr 25, 2007 | 01:27 PM
yeaa im looking at streat beat customs right now.. i sorta need them asap ... as far as everything else.. i think i should jus let them change my engine mounts and everything else i can do somehwere else..
Old Apr 25, 2007 | 02:17 PM
VIPCLS's Avatar
P.
I had my tranny replaced also and acura tryed to come up with all these things I needed to replace also just like your case. They said I needed new brakes and one of my engine mounts needed replacing. I knew I probably needed new brakes soon, but I asked the service technician how long I had till the brakes were gone and he said ooooooo about 4K miles or so. Its been well over 4K miles and my brakes are working just fine, except for a little warp shakin goin on but Ill get them replaced soon. But just goes to tell you that they are just in it to make a buck most of the time. All in all I think its a bad deal if you ask me. Do the more easy stuff urself let acura handle the rest.
Old Apr 25, 2007 | 02:34 PM
SG81's Avatar
Missing My CL-S
https://acurazine.com/forums/sponsored-sales-group-buys-10/rotora-slotted-drilled-slotted-rotors-special-cl-tl-tsx-324531/
http://www.ExceleratePerformance.com
Good guy too (Josh) which is why I recommend everyone to support him
Old Apr 25, 2007 | 02:43 PM
Well, if they've got your car in there replacing the tranny under warranty, they aren't making any money from that, they're more than likely loosing money. Most of the people that still have OEM rotors either are warped, or have been warped and turned, both of which will need replacing at one point in time. They figure it would be a quick way to make ~$500 since the car's up on the lift anyway.
Old Apr 25, 2007 | 03:05 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
Change the tranny fluid? That b/s, should be replaced with the tranny no charge. I was never charged for that crap.
Which mounts are they going to change? I'd check for prices on http://www.acuraoemparts.com/delray/jsp/home.jsp and other sites to get an idea, I believe labor should be free while the tranny is being changed, it was in my case, I had the front one changed for $170, which I probably was getting screwed on.
$500 sounds like an @r$e raping for front rotors and back pads! I got all four of my aftermarket crossdrilled/slotted rotors w/ pads for less than that and now I can stop on a dime. My friend's call them Turbo Brakes.
(I did get them at whole sale price b/c of my friend , but even then they still would have been just around $500 for all four rotors w/ pads)
I'm sure Excelerate can hook you up with a good deal on brakes!
Old Apr 25, 2007 | 04:21 PM
well i jus got off the phone with them.. they said that the tech is sayin my tranny is fine .. jus the mounts that are worn n the fluid that is burnt thats making it jump alot... soo altogether will be about 550 including tax... in this it includes replacing the front and side mounts and new fluid + labor
i figured i might as well get this fixed.. as far as my tranny goes, they said i have an extended warranty on them so 109 k or 93 mo. which ever comes first for my tranny if anything happens down the road...
as far as brakes goes... i am interested in after market brakes so if you guys can lead me in the right direction i would be really thankful
thanks for the replies
Old Apr 25, 2007 | 04:40 PM
HERE:
Originally Posted by SG81
https://acurazine.com/forums/showthread.php?t=324531
Old Apr 25, 2007 | 06:48 PM
oakes57's Avatar
3rd Gear
Auto dealerships are franchises owned by individuals, they are paid for the warranty work by Honda/Acura since that is who the warranty is with. So they are not losing money at all, they are paid for it. They still try and avoid warranty work sometimes because it looks bad if they have alot of them. And of course they are going to try and get more work done out of you while you are in there. But never feel sorry for the dealer, that is like feeling sorry for your insurance agent if you have a claim because you think he has to pay for it personally.
sockr1
Oct 1, 2015 01:31 AM
PortlandRL
Sep 14, 2015 12:01 PM
DDTsx06
Sep 8, 2015 06:56 PM
NSolace
Sep 3, 2015 08:02 PM
