going to the track tonight: whats my time?
Old 06-03-2011, 12:44 PM
  #121
fuzzy02CLS's Avatar
lightweight wheels
Actually my SSR comps I think give less traction. It's so much easier to spin my tires off the line & that leads to wheel hop. Maybe if they had drags on them it would compensate.
Old 06-03-2011, 04:59 PM
  #122
AARONSredTYPE-S's Avatar
makes sense, but lightweight wheels with sticky 235 tires would be awesome i think...
Old 06-03-2011, 05:30 PM
  #123
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,381 Likes on 4,930 Posts
Theyll make a difference in you 60ft times but your trap will probably still be low. Your intake temps are too high, so its not making all the power it should up top.
What mods have you done to date?
Old 06-03-2011, 07:48 PM
  #124
p2r intake manifold spacer,p2r tb spacer and dual gaskets, 3" cai, xs power headers, 2.5" exhaust straight to a single in/ dual out 2.5" muffler(no mid-muffler), e3 plugs, slave check delete, coolant tb bypass, neuspeed race springs/ struts, falken 225/45/17 tires on stock wheels
Old 06-03-2011, 08:43 PM
  #125
ChucksCL-S's Avatar
I too think it is the heat. Plug in corrected times for a 60 degree day and see what that 14.2 turns into.
Old 06-03-2011, 08:53 PM
  #126
Originally Posted by chuckscl-s
i too think it is the heat. Plug in corrected times for a 60 degree day and see what that 14.2 turns into.
i have lower trap speed and barely a better time than you and you are an auto-tragic..wth...lol
Old 06-04-2011, 11:26 AM
  #127
TQ > MPG
Joe5.0's Avatar
It really is all in the 60 ft. Get lighter wheels (go with 17's for sure) and some drag radials and you'll run 13's.
I dont even bother going to the track if its above 80*, it really just kills your times.
I say go with 17's because you can find 17" drag radials in the sizes you need, and the more sidewall the better, as they will absorb the shock of the launch much better. Hell, I would have went with 16" wheels if I knew of a 16" drag radial that would've worked.
Old 06-04-2011, 11:45 AM
  #128
YEAH, well even a 2.1 60ft only got me a 14.2, but i understand what you are saying.
hell, if you would have had my mods on your car, you would have run a 13.4-13.5...lol
i probably wont go to the track for a long time because im tired of the same times.
btw shifted at 7200 and tire pressure was 25lbs, and launched at 3k feathing the clutch...no wheel hop, but tires spin once im full throttle and churp through 3rd..
Old 06-04-2011, 01:21 PM
  #129
reese8789's Avatar
Hey the exhuast you got is it mandrel bent or pressure bent? If it is Pressure bent then its like your running 2 1/4 exhuast so then it would still be pretty much like stock. When I went from stock exhuast to 2.5 inch mandrel bent I gained about 1mph in the 1/4.
Old 06-04-2011, 02:33 PM
  #130
im gonna change my exhaust because i dont like it, but it is mandrel bent, but most of it is straight..i should have picked up some, but my times didnt change at all..
Old 06-04-2011, 03:08 PM
  #131
ChucksCL-S's Avatar
Aaron the day I got the time I listed it was 55 degrees. I iced down the intake for an hour before that run, which was run #2. On run #1, I lined up beside a custom turbo 350Z and he spun bad, he only passed me in the last 200 feet of track. We ended up parking next to each other and he was shocked at how I took off and thought I had nitrous. My mph on that run was 99, he had extra ice and said "here use this ice for an hour, you need to break 100". Nice guy he was, it worked! I was happy so I went home.
Old 06-05-2011, 04:01 PM
  #132
well, i was thinking the heat obviously has a huge factor, but i still think something is wrong and i will be thinking of ways to get my car right..thanks for all of the replies so far...
Old 06-06-2011, 07:59 AM
  #133
fuzzy02CLS's Avatar
Nothing is wrong. I keep telling you this. Wait till December or January & run again.
Old 06-06-2011, 09:44 AM
  #134
why is our car affected by the heat sooo much. other cars out there were running normal times.
plus, i am worried that maybe i need a valve adjustment because my car seems to be very noisy. i wish i knew what the engine is supposed to sound like so i could know if i had an issue.
but the heat that comes off the engine bay is insane too, i can feel it at night time if i have the windows down and it hits my arm like a damn heat gun..lol
thanks guys..i might go one more time before summer is over, but i just have a feeling that something isnt wright, but maybe its all in my head...lol
Old 07-05-2011, 11:07 PM
  #135
well, ive changed my spark plugs to the Ngk iridium ix's, changed my intake to the Aem v2 cai, and im getting some Toyo R1R's for the front in 235/45r17's...Oh, and going to straight, single exhaust....
I will be headed to the track on the 16th,(next weekend) so what do you guys think I will get this time?...lol
im thinking 13.8
Old 07-06-2011, 07:48 AM
  #136
fuzzy02CLS's Avatar
You still will not brake 14.0.
AARONSredTYPE-S (07-06-2011)
Old 07-06-2011, 07:58 AM
  #137
dont think so huh?
why is that?
Old 07-06-2011, 08:57 AM
  #138
StreetKA's Avatar
do you really shift quick enough ? let me tell u something lately i raced a friend that he got basicly same mods that i do and i was still pulling on him to be honest why i dont know sometimes its fuel sometimes its driver sometimes its a other thing that is with the car... post a video next time from the inside of your car so we can see how you're doing im not trying to say that u cant drive a stick but lets say did you remove check valve from slave cylinder ? or do you have good engine mounts ? this counts alot with good UHP tires u can get 60ft to 2.1 easy maybe less u just need to keep trying to get perfect launch
btw im getting P&P intake and runners now and im changing midpipe to custom 2.5" SS with 18" Vibrant resonator so it should make a differance too i will post results as soon as i get mounts done too...
Old 07-06-2011, 10:01 AM
  #139
AWESOME MAN.
YES, I am a very good driver. My 60ft is also between 2.1 and 2.2 most of the time. I do have the check valve deleted, but no ss lines yet. I do shift very quickly and precise.
I'm getting a dyno very soon, maybe even before i go to the track next week, to see if my car is even putting down the power it should...240-250whp?
I may just have a weak motor...135k miles...or clutch even?
those mods you wanna do im sure will help you out, and i cant wait to see what you get at the track next time...
i will try to get a vid of the dyno and track next week
Old 07-06-2011, 12:20 PM
  #140
fuzzy02CLS's Avatar
dont think so huh?
why is that?
Same as before weather. Too hot too humid. Maybe I'll be wrong, but I doubt it.
Old 07-06-2011, 12:44 PM
  #141
very true, god it is sooo flippin hot and humid...
I really hope to prove you wrong though..
Old 07-07-2011, 06:38 PM
  #142
ordered the Bridgstone Potenza RE-01R's tonight in 225/45r17 for the front....
Hopefully these will help me next weekend
Old 07-10-2011, 01:29 PM
  #143
Doesnt look like my tires are gonna be here before the 1/4 mile event saturday, so i may just get the dyno instead this week:i
Old 07-16-2011, 08:14 PM
  #144
installed tires and they are sooo flippin good.
No spin in 2nd or chirping 3rd, just straight pull and ride wonderful...even in the rain...extremely quiet too...cant wait to see how much these help at the track
Old 07-16-2011, 09:27 PM
  #145
3.7L Nitrous Breathing CL
richardparker's Avatar
think your good for 14 flat now ?
Old 07-16-2011, 10:27 PM
  #146
YEAH, EVEN IN THE HOT ASS HUMID WEATHER..Car responds way better now, and i would suggest these tires to anyone, or the Re-11 that replaced them this year
james357
02-13-2016 02:37 PM
advan031
5G TLX Photograph Gallery
11-14-2015 07:44 PM
forrie
09-15-2015 09:57 AM
Quick Reply: going to the track tonight: whats my time?
