FYI Easy install - M6 lights
Old Feb 11, 2002 | 10:36 AM
mistacanyon's Avatar
Mr. PC
Just FYI:
I was really tired of breaking those damn M6 bulbs when trying to install them. For those familiar you know the hole in the lamp the bulb goes through is smaller than the bulb. So I decided to sand down the hole a little bit with a Dremel tool. Worked like a charm! The housing snaps back into place and there is no issue with moisture leaking in because the rubber seal goes to the outside of the hole. Now the bulbs can be removed and replaced without breakage!
Old Feb 11, 2002 | 10:37 AM
HellaWhat's Avatar
*Hella* isn't a word.
I basically realized that to get them out of the socket, you have to twist and turn the bulb out of the socket, can't pull it striaght out or it breaks.
Old Feb 11, 2002 | 10:39 AM
Mr. PC
Even when I would twist it in about halfway the bulb would pop from the pressure. Maybe it was cold or the hole in mine was smaller, but it works sooooo much better now!
Old Feb 11, 2002 | 10:42 AM
HellaWhat's Avatar
Okay, fine, jiggle then twist? I seriously broke one cause I tried pulling it out with pliers. The other one made it out with the jiggle-n-twist-method and is now powering the license plate light.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
PortlandRL
Sep 14, 2015 12:01 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
