Front wheel bearing question
Old Apr 8, 2010 | 01:14 AM
CivicB18B1's Avatar
Hi guys, last year my front left wheel went into a big pothole and caused a flat tire.. since then, my wheel bearing is making some noise and its time to change it.
My question is, do i need any special tools to make the job? It is a easy DIY?
Thanks!
Old Apr 8, 2010 | 08:55 AM
anthracitecl's Avatar
I think this is best choice. remove your knuckle and take it to your local shop w/new wheel bearing. They should replace it within 30 minute.
Old Apr 8, 2010 | 09:46 AM
pits200's Avatar
Anthracitecl, that is a lot of extra work to replace the wheel bearing, perhaps you are thinking of the lower ball joint?
For the wheel bearing, its the entire hub assembly that needs to come off and the knuckle does not need to be removed to do this. The easiest thing to do is to not just buy the wheel bearing, buy the entire hub assembly. Here are the steps.
1.) With car on ground, remove the center cap on the wheel.
2.) Get a long breaker bar with a pipe on the end and a large socket to fit over the axle nut. (Can't remember the size but its in the high 25-30mm size I'm guessing)
3.) Just break the axle nut loose ever so lightly.
4.) Jack up the car, remove the tire.
5.) Remove caliper housing using the two 19mm bolts(I think thats the size)
6.) Pull off the rotor
7.) Remove the axle nut the rest of the way.
8.) Work off hub assembly from the axle.
9.) Replace with new hub assembly and put back together.
I may be missing something, its been awhile since Ive done this job.
Its fairly simple and straightforward. Good luck
Old Apr 8, 2010 | 10:04 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
How much is the whole hub assembly.OEM and after market.
I almost bought just the bearings not that long ago just to do them.
I've seen the rear assembly before but,never the front.
Old Apr 8, 2010 | 10:15 AM
CLPimpin114's Avatar
Tokin up in
Does the Hub assembly have to be machine pressed on? Remember back to my 96 TL they had to be machine pressed
Old Apr 8, 2010 | 10:44 AM
SG81's Avatar
Missing My CL-S
when i replaced mine, i used a press. if you don't, it may not sit properly. but you don't "have" to use it
Old Apr 8, 2010 | 10:54 AM
pits200- I got a question. how did you replace hub bearing assembly w/o removing knuckle? I've never done this car. but i did few hondas. I needed press machine. That's why i said that. like GM cars, you don't have to remove knuckles. they are hub bearing assembly. you just loose 3 bolts and it just come out.
Old Apr 8, 2010 | 10:57 AM
Elijah J's Avatar
Thanks!
Ive also nailed some potholes. What is the noise you are hearing?
Old Apr 8, 2010 | 11:03 AM
Maybe it's just me. I always removed knuckle when i did wheel bearing.
except bolt on type.
Old Apr 8, 2010 | 11:36 AM
pits200's Avatar
I started a thread when i removed the knuckle to take it into a shop to change the lower ball joints. Now let me find it.
https://acurazine.com/forums/showthr...light=axle+nut
Hmmm, now you have me thinking, lol.. I was thinking of replacing the rear assembly and not the front??? I think you're right Anthracite about it needing to be pressed in. Damn it!! My apologies.
Old Apr 8, 2010 | 07:12 PM
russianDude's Avatar
had that happen to me, go to a reputable mechanic, its a ~$200 job, dealer will charge $600.
Old Apr 8, 2010 | 07:18 PM
Tokin up in
Ya man plz do1 i Cheaped out and took my Old car to Brakes plus and F**kers Hammered the Hub into place. A month later it failed on me again. Took it to dealer and they showed the parts, Took it back to That crap shop. They tired to refuse to return my Money till i threated to Sue.
Old Apr 8, 2010 | 07:22 PM
I did not say to take it to any place, if you have a good mechanic you trust he can certainly do it. Replacing wheel bearing is pretty much standard job, no need to be a dealer.
Old Apr 8, 2010 | 10:42 PM
Tokin up in
Haha My Bad man missed read ur post
but ya thats my little story
Old Apr 12, 2010 | 12:47 AM
dave586270's Avatar
Chamorro
If its just a bearing then there is no need for a new hub. Our bearings are press in. Most shops can do it right there. 30min-1hr depending on the tech really. I work in a shop so i get a crazy discount on parts. $200 sounds about right depending on the bearing.
Old Apr 16, 2010 | 11:17 PM
holeshot_04's Avatar
what kinda of noise was it making? i might need to do this.
Old Apr 20, 2010 | 12:41 AM
dave586270's Avatar
Chamorro
Its usually a whiring, or a grinding sound, maybe rubbing? It should get worse when you put load on it (turning). Which ever way you turn and it gets louder the bad bearing is on the opposite side.
Left Turn gets louder = right bearing bad
Right Turn gets louder = left bearing bad
Old Aug 31, 2019 | 01:55 AM
2010TLtech's Avatar
TL wheel besting and HUB
2009+ Acura TL’s only have Bearing Hub Assembly on the rear wheels for the FWD models. The front bearings and HUBs are sold separately and the bearing must be pressed in and then the HUB pressed in. Attempting to do this without removing the knuckle can damage the bearing and you will end up right back where you started. I just replaced mine today and the Hubs were only $89/ea andbthe bearing set L/R was $79. I recommend taking the knuckles off and paying a local shop about $35 per side to press them out to prevent knuckle damage and the shop will press the bearing and then the hub back into the knuckle. It took about 45 min to an hour to remove both knuckles and an hour to/from the shop and another hour to get it back together. You will spend less than $400 on a job that mstvshops will charge $1200-$1600 to complete.
woolly
Old Sep 28, 2019 | 03:41 PM
ProfessorFunk's Avatar
Resident Smart@ss
Originally Posted by 2010TLtech
2009+ Acura TL’s only have...
  1. This forum is for 2000 - 2003 CL's.
  2. This thread hadn't been touched in 9 years.
Just sayin'.
Feb 25, 2020 09:57 AM
heyitsvic
Sep 4, 2015 09:38 AM
nuldabz
Sep 3, 2015 05:49 PM
