Front Pads
Old Jun 8, 2003 | 02:37 PM
Dave's Avatar
Front Pads
I did a search here with no luck. It looks easy to replace the front brake pads, is it? It looks like you remove the two bolts on the caliper, remove the master cylinder cover, use a clamp to depress the piston and insert the new pads. Am I about right? Thanks
2001 cls - stock
Old Jun 8, 2003 | 04:16 PM
Dave's Avatar
Man, I may have to let the wd40 soak for a few hours - The caliper bolts are really cranked on! Do you first have to loosen the nuts adjacent to the caliper at all to remove the bolts?
Old Jun 8, 2003 | 05:42 PM
Dave's Avatar
Okay, got'em with the wd and a breaker bar! Whew after the bolts, it is easy!
Old Jun 8, 2003 | 06:04 PM
Dan's Avatar
Dan
Confused
The man is talking to himself, on a message board!
Old Jun 8, 2003 | 06:18 PM
6speedctrlfreak's Avatar
HHMMMM....Interesting....."Dan"...then "Dave".....next post will be from "Bill". Whatever happened to imaginative screenames !!!!
yesSIR-S
May 13, 2016 05:42 PM
08 NBP TL
Sep 8, 2015 08:49 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
Sep 4, 2015 08:03 AM
nishant11
Sep 2, 2015 10:34 AM
