front end overhaul
'03 ABP YA4-S 6MT
front end overhaul
doing the clutch and since my front end is apart, gonna have the shop do some maintenance items at the same time:
1. upper and lower balljoints (moog)
2. axles (cardone)
3. wheel bearings (timken)
4. input shaft and rear main seal (acura)
5. inner and outer tie rods (moog)
using MOOG products where i can, but can you guys think of anything else? should i replace the control arms? or the hubs? i was gonna do the subframe bushings but i'm too lazy to look up all the part numbers.. maybe the control arm bushings and radius rod bushings?
2. axles (cardone)
If you decide on replacing the inner and outter control arm bushings, I suggest using Honda OEM parts because the Moog's are soft. I had to replace the outer ones after only 10 months or so.
https://acurazine.com/forums/2g-cl-tires-wheels-suspension-54/simple-ball-joint-separation-740248/
I'm looking at replacing my front wheel bearings in the near future. A Honda dealership told me that the OEM bearing brand they stock are NSK. They (Honda) wanted $102.56 just for the bearing. I found them at the link below for $47.94 each.
http://www.partsgeek.com/catalog/200...l_bearing.html
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
