Front end knocking/clicking..help!
*6MT*
1 Post
Well, i put my coilovers on a few weeks ago, and since then I have been getting some knocking/clicking noises going over VERY small bumps.
They don't make any noise when going over big bumps, or speed bumps.
It is a very subtle noise, but a very annoying noise in the least.
I don't think it is a coilover noise, but i could be mistaken. It almost seems like I left a bolt loose, or something to that affect.
Any suggestions?
Any suggestions?
Most likely its the sway bar end links. VERY COMMON problem especially if you have an upgraded sway bar.
I just changed all 4 this weekend. Also, they don't have to be broken to make the sound, they can be loose.
Also, the clicking can be from you not putting the rubber stops on properly while reassembling the spring/shock combo.
Is it both sides?
Is it both sides?
Is it both sides?
Is it both sides?
what he said..............
Regional Coordinator (Texas)
most likely its the sway bar end links. Very common problem especially if you have an upgraded sway bar.
Is it both sides?
Is it both sides?
Maybe try some WD 40 on everything in the front suspension. For things like ball joints or tie rod ends with boots containing grease (and no grease fittings anymore these days) I simply use a grease gun with a needle fitting. They are available at auto parts stores. Just puncture the boot and fill it up. Sounds like two dry metal parts to me are rubbing together. Hope you can find it. When you do please let us know, thanks.
Whats up with RDX owners?
Check to make sure you don't have a loose bolt. That could very dangerous.
*6MT*
1 Post
I should probably state that it is NOT a loud noise at all.
When i loosened my RSB there was a very loud knocking. This is NOT the same at all.
It is a very subtle knock, just an annoyance.
*6MT*
1 Post
i bought the coilovers used, about 10k miles on them from a TL auto user.
The sound has gotten a little worse throughout the day, but it has gotten colder too, if that makes a difference.
Alex, this will probably work from the TL thread above. I bought some coil isolators from Tein and they're pretty cheap and easy to put on. That's what i did to the rears on mine.
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
