Friggin' Valve Spring Compressors
Giant Blue Car
I can't do a forum search on my stupid phone, so...
What type/brand of valve spring compressors do I need to get my old valves off?
I've tried two different ones that are the screw-type, but I can't get them around the springs!
To get them off use a dead blow hammer and tap/hit on the valve springs with it. It will pop the retaining clips out and you will be able to remove them.
To install them, I bought mine from sears, then i took a deep well socket and cut a opening on one side to gain access to the retaining clips.
Similar to this
Similar to this
Giant Blue Car
Ooooh thank you, fstty! ! ! I knew I should've went to Sears or Elliot's! The auto parts shops only have that screw-type.
As an aside, I may have "recruited" a new member in my tool-hunting crusade today...
Giant Blue Car
So, I've got them compressed, hit them with a hammer? On the side of the spring? When I saw those little devil-clips, I started thinking maybe I shouldn't even try to get my valves out... I despise clips like that!
Go to about 3:30 in to see what i mean
Catfisha (10-20-2013)
Its far far easier to remove them just by placing the socket on top of them and giving them a few hits with a hammer. They pop right out. It will take you a min to do each head.
Giant Blue Car
So, should I hit the socket hard? I'm having no luck with that either!
Giant Blue Car
I'm giving up until none of my neighbors are home. I'm sure I'm bothering them with all the noise and yelled profanities....
I must be doing something wrong, 'cause I don't see evidence of those keepers giving way.
Yep, them things be leaning.
Catfisha (10-23-2013)
Giant Blue Car
If only I had a garage, but....
THANK YOU ROBERT!!! for bringing my little gorgeous back to life!!!
Thank You! It SURE is! I've missed my dearly....
J-series addict
But in terms of physically checking them: once the valve covers are off and the rockers are loosened off of the valve itself, its just a matter of seeing which ones are still stuck in the "lifted" position. When the cam lobes are no longer touching the valves (via the rocker shaft), its obvious that all the valves should be equal in height. If you take a straight edge ruler across the tops of the valve stems and see one or more not touching the bottom of the ruler, the valve(s) is bent. Generally its the intake valve that gets bent when the belt breaks.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
