FRAM filters ok?
Old Jun 8, 2010 | 02:42 PM
belcom's Avatar
09 TL SH-AWD
FRAM filters ok?
Needed to change oil quick and didn't have time to stop by the dealership to pick up a honda oil filter like I usually do. They installed a FRAM filter with the usual 5-30 Mobil 1 synthetic.
Are those filters reliable for 6k-7k with synthetic oil?
Old Jun 8, 2010 | 02:48 PM
its reliable. I've used Fram in my other older vehicles. (98 toyota corolla, 99 chevy malibu, 02 dodge ram, 04 nissan frontier.)
not sure if its the best at filtering, as there are other brands that are better but I have had NO problems at all.
Old Jun 8, 2010 | 03:11 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You're fine.
Old Jun 8, 2010 | 03:54 PM
civicdrivr's Avatar
IIRC OE Honda filters are made by Fram.
Old Jun 8, 2010 | 05:41 PM
russianDude's Avatar
cheap FARM used to get bad reviews when people cut their oil filters, but if you buy more expensive FARM its better made.
Our engines are very reliable, you don't need to baby sit them like our transmissions... so regular filter and oil will work also
Old Jun 9, 2010 | 11:36 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
yep they're fine
Old Jun 9, 2010 | 06:21 PM
aznboi2424's Avatar
True.
Fram arent extremely bad filters but there are better filters you can get from the money. And with running 7k intervals, I would use a better filter. Im running 8k intervals on purolator pureone, wix, napa gold or fram extended guard.
If you decide to use cheaper filters, purolator classic or even walmart supertech filters are okay. I'd pick either of those then a fram.
Old Jun 10, 2010 | 09:54 AM
(Mid-Atlantic)
For longer intervals I would use a mobile 1 filter, but I'm biased
Old Jun 10, 2010 | 12:38 PM
tnobori1's Avatar
Missing my
same here... Mobil 1 filters and oil
Old Jun 10, 2010 | 12:52 PM
OEMAcuraPartsTim's Avatar
Former Sponsor
I used a Fram in my Chevy van at last change because AutoZone had a special , which I had no problem with....although aside from OEM, I think that Hastings makes the best filter made. I drive an extra 20 miles to a parts store locally that carries them.
Old Jun 10, 2010 | 03:37 PM
aznboi2424's Avatar
I didnt mention mobil 1, K&N, amsoil or royal purple cause I think these filters would be a bit overkill for his 7k intervals and it seems like OP definately doesnt want to spend nearly 10 bucks on a filter.
Old Jun 10, 2010 | 03:40 PM
civicdrivr's Avatar
IIRC the Amsoil filters last 25k.
Old Jun 10, 2010 | 03:44 PM
aznboi2424's Avatar
or 1 year as rated by amsoil. and definately more then any over-the-counter filter but the best filter out there.
Old Jun 10, 2010 | 06:00 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
MOBILE 1 filters and oil here too..
and i import my filters since they don't sell them here!...
now that's customer loyalty
Old Jun 13, 2010 | 08:34 PM
belcom's Avatar
09 TL SH-AWD
I always buy OEM, this time under circumstances I had to install FRAM extended guard one. just asked for opinion on reliability. read the original message.
Old Jun 13, 2010 | 08:58 PM
aznboi2424's Avatar
i was just responding to the post above it.
in your case, fram will be fine. honeywell also makes the OEM filters, similar construction.
Old Jun 16, 2010 | 03:53 PM
ANC297's Avatar
Bonki' Ehrite!
I use oem filters...
Old Jun 16, 2010 | 05:37 PM
ok for normal change intervals, but not adequate for extended 7500miles+
Old Jun 16, 2010 | 06:05 PM
aznboi2424's Avatar
even though Acura/Honda's owner manual says you can change the filter every other oil change.
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
jmaxima03
Sep 27, 2015 10:22 AM
