Footwell Lighting
Old Oct 5, 2003 | 05:22 AM
Mr Zipps's Avatar
Footwell Lighting
Im going to install neons under the driver and passanger footwells and also under the seats for the rear passangers.
I want to install them to so they light up when I open the doors. That is not going to be a problem because I will tap it into the dome light.
Here is the real question.. I want to be able to put a switch inside so I can turn on the lights while im driving....
Old Oct 5, 2003 | 06:29 AM
Python2121's Avatar
The hair says it all
if you ask me i think it would be cooler to put dim white led's under the seats that project onto the carpet
i dunno i think that would look classier, but either way good luck
Old Oct 5, 2003 | 06:34 AM
Mr Zipps's Avatar
Im going to put blue neons underneath. I though about the white lights but I saw a car with blue neons and it sold me. I though it would look a little ricey but it doesnt. I compliments the outside of the car when the doors are open...
Thanks for the suggestion.
How would I go about wiring to a switch....
Old Oct 5, 2003 | 07:03 AM
CLpower's Avatar
teh Senior Instigator
hello and welcome back to the 80's, i'd go w/ the white LED's, much more pimp.
Old Oct 5, 2003 | 08:42 AM
Mr Zipps's Avatar
Thanks for the suggestions but does anyone know how to wire it to the dome and to a switch.....
Old Oct 5, 2003 | 09:18 AM
AztecRol's Avatar
The Screeching Toyo's
What you need to do, is take the wire from the dome light and a wire from a 12v ignition one source, like the radio, and run them both to a single pole double throw switch. In one position, say up, the neon will come on with the dome light only, in the seconde position, down, the neons will come on any time the key in the ignition and is in the acc or on position. If I could draw it for you here, I would. But it would be too hard.
P.S. I woldn't use the radio wire, I am sure you will get noise on the radio if you do. Just using it as an example.
Here:
Old Oct 5, 2003 | 03:47 PM
SilverKnight's Avatar
Retired. Not available.
There is a wire at the passenger fuse box which goes to the dome lights. Becareful with this wire, if you short it, your whole multi-plexed control box is out of commission. randomwalk101 tried it and it was not fun
Oh, and dont put too much load on this wire, you can overload the multi-plexed unit. Try to use relay.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
