Fog light Bulb super white LED converion project
Hi guys,
Our car use 9006 bulb for the fog light.
I am in the process of converting this bulb into super white LED bulb. What I have done is take this blub and removed the class tube and take the bulb's plastic connector to be used on my LED circuit. I know there are 9006 LED bulb out there on the market but mine is VERY BRIGHT super white light. As a matter fact the light output is 5x whiter than our HID low beam! The secret is that I was able to get high power 8mm super cool white LED from a Korean manufacturer. I used 5 LEDs for each bulb and each LED is rated at 80mA (compare to standard white 5mm LED which is rated at 20mA). I don't have any pictures to show you yet but as soon as I put everything together I will post them for you. I can't wait to see the final installation!
hchhon
Hi guys,
hchhon
OK guys,
Here is the first version of fog light with super cool white LED bulbs.
I only used three super white LEDs on this one and final version will have 5 super cool white LEDS. http://www.acurainspired.com/gallery...d=768&uuid=112
Busy Living
excellent job. I've actually got a somewhat similar project lined up. The CL's do no use a 9006, CL's come with a cheesy 5watt bulb. I picked up some 3mm white LED's and I plan on aiming them (about 6 per side) into the housing to give it an effect of a well lite housing. I want it so you do not see the LED itself, just the reflection of it's output.
what part of NC are you in? How did you handle the voltage step down?
Originally posted by CL®
maybe you should make a comparison with them installed, so that people can compare them with the headlight.
also you might think about doing this for the CL.
I am from Boston.
hchhon
Hi,
I just found this thread listed on google, I was doing a search for 9006 LED's. I was hoping to find some premade 9006's LEDs but haven't had any luck. So I think I might try this project for the foglights on my 04 4Runner.
mthuch, are you still happy with the output of the LEDs? Do they seem brighter then the stock 9006?
You wouldn't happen to have some step by step instructions do you
The pictures of the LEDs lit in the housing look really good, and that's what I'm hoping to do with mine.
Chris.
Chris.
the guy you're looking for has been banned from this site. i don't think anyone had much success w/ led driving light bulbs for a cl-s. they weren't bright enough.
you're welcome to start a new thread and ask.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
