Flints S/C 1/4 time slip
1 Post
Here is a pic i took of his slip that night at the track, his first run with the S/C!! he is the one on the left. He has a 01 CLS auto..and he was running w/his 19inch Lownerhart wheels!!
![](http://hometown.aol.com/itwasntmedistime/images/fntscrun.jpg)
Originally posted by darrinb
wow, i wonder what he can do on samller rims
It is a rough calculation, but if you lose .1 from your 60' it usually means .2 off your E/T
1 Post
Originally posted by UNCTYPE-S
nice run, but just curious who ran the 12?
Audi S4 driver
Yeah he should definetly be able to beat a 2.2 60ft without those 19s .. I made a 2.17 60ft with my 18s and he has ALOT more low end torque than I do.
In the probably 40-50 passes I have made at this track I have never been lower than a 2.2X 60 ft time. No matter if I run 19's with t1s's or my stock 17's with sumitomo htr+. I doubt I ever will because the setup at this track forces you to go through the water box to get to the staging area. The water box kills my launch every time with my wet tires. I try to burn out after the water box to get the tires dry but there is always water between the treads that runs out. The only solution at this track is drag radials. ![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Great run, flint. I hated Edgewater when I lived back there -- mainly because it was in scenic FrogTown.
I bet that track will be real sticky once dead cicadas are littering the starting gate!
![Huh](https://acurazine.com/forums/images/smilies/huh.gif)
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
1 Post
lovely FrogTown!!!!! and it might be sticky but all the drag from smashed cicadas on the front will off set it!!
Mike Bertram
09-10-2015 09:27 AM
