Flashers/turn indicator lights won't turn off
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Car is an 2003 Acura 3.2 CL/S ---
For no apparent reason, all flashers (ie, turn indicator lights) have decided to flash continuously, without turning off.
The only way I have found to make them quit is to remove the flasher control box under the dash, to the left of the steering column.
I went to an auto parts store and bought a replacement for the control box and inserted it where the original control box was --- all flashers flashed continuously just like with the original control box, so my original flasher control box appears not to be the problem.
How do I get my flashers back to normal???
have you tried turning off the emergency lights , is that depressed by chance?
Thank you for your suggestion.
My first action was to check the Emergency Light switch.
It was off.
I turned it on & off in succession --- the flashers continued to flash with the switch in either position.
Problem doesn't seem to be related to the Emergency Lights, although I agree that appears to be a likely issue.
Thanks again for your response.
It was off.
mge2790
02-11-2008 09:26 PM
