fix brake light on tachometer
Old Jul 28, 2006 | 10:52 AM
DBLOCK1226's Avatar
B A N N E D
got a 01 CL-S and the word brake on my tachometer keeps coming on while im driving but the emergency brake is not on. what could be causing this and how can i fix this.
Old Jul 28, 2006 | 10:56 AM
NSXNEXT's Avatar
Doesn't it come on if a brake light is out. Sounds like maybe one is on its way out.
Old Jul 28, 2006 | 11:06 AM
Lord Helmet's Avatar
I'm here in spirit...
Either that or check your brake fluid level.
Old Jul 28, 2006 | 11:33 AM
GreenMonster's Avatar
Something is wrong w/ the brake system... the warning light is there for a reason... better check it out...
Old Jul 28, 2006 | 01:40 PM
cltypeSLOW's Avatar
Don't Mess With Texas
mine comes on every day at first start up when engine is cold for about 15 min...then it goes off. i think its something with the float in the reservoir.
Old Jul 29, 2006 | 03:19 AM
superfob's Avatar
Mine used to come on randomly as well. I opened up the brake fluid reservoir and pushed the float that was inside up and down to make sure it wasn't stuck. I was going to change the reservoir cap which has a sensor and before mentioned float as other members have done. However The light stopped coming on for no reason after tinkering with it . So I left it alone. If you do decide to change the cap sensor it's around twenty dollars I believe.
Old Jul 29, 2006 | 03:37 AM
kensukikatayo's Avatar
Turbo + Sound = Hey-pee
Happened to me too. I'd jus tap the e-brake (don't push it too far while driving. DUH!) and it would go off. Sensor was most likely bad since I just did a brake fluid flush/refill/bleed and it would come on randomly when I hit bumps in the road.
Old Jul 29, 2006 | 08:40 AM
BigLizard's Avatar
Moderator Alumnus
Sweeeet. I love brake systems. Always a mess to clean and fix.
Old Jul 29, 2006 | 02:46 PM
paul01cls's Avatar
5th Gear
I had the same problem with my brake light. It would turn off after 15 minutes or so. I ended up bleeding the brake system and replacing the fluid, worked like a champ for me. The light now only comes on when the E-brake is on.
mada51589
Jan 9, 2025 04:40 PM
JnC
Sep 11, 2015 06:06 AM
nishant11
Sep 2, 2015 10:34 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
