Finally used the oil boy oil change pump over the weekend, works great
that pump works great. to manage the curvy tubes that still had oil residue in it, i rigged up a stand using 3/4" pvc and a collector bottle. i'll build a real stand (maybe a cart for it all) when i have the time.
![](http://imageworm.com/uploads/temp 015 (Large).jpg)
i also bought a 5 gal. container to haul the used oil off to recycle. i can do a few oil changes before i make a trip. it only cost six bucks and change at wally mart.
![](http://imageworm.com/uploads/temp 018 (Large).jpg)
i also picked up some nice compact and lightweight jackstands at pep boys. damn things cost $40.
![](http://imageworm.com/uploads/temp 013 (Large).jpg)
My Member is Registered
I just bought mine today and used it too! It also worked like a charm. Can't wait to try it on my tranny fluid, I just bought some Amsoil.
BTW, excellent idea with the used oil container, it was a messy clean-up getting the suction tubes to clear for me.
Originally Posted by Zapata
you stick the hose where you fill the oil?
Cost Drivers!!!!
Originally Posted by RaviNJCLs
The tube goes down the opening for the dipstick. Works great. Took me no time to change the oil the last time I did it.
ah sweet...thx
Originally Posted by mrsteve
Does it completely remove all the oil? Or should it be expected that some is left behind?
1 Post
hmmm... well I need to change my oil pan as the drain bolt is seized up in there, so i can't drain the oil and the only way i could get the oil out to change the pan is with this thing. How much did it cost you. i'd imagine anything is better than $150 in labor + $80 for oil pan and gasket.
anybody think i shouldn't replace my oil pan on my own?
imo, it removes about the same amount of oil that a normal gravity drain would.
this is what is did: after the the pump sucked out most of the oil (pump not full yet), i emptied it and pumped out as much as a could again. i probably got a couple more ounces out at most.
they have a variety of them. http://westmarine.com/webapp/wcs/sto...169&storeNum=6
do you have an air compressor? there are some models that work off of one. look up mityvac.com .
you could always bring the car to the dealer for an oil change and hope that they strip the pan threads and perform the repair. kinda messed up, but if you you don't care...
IMO This is the PERFECT tool for an oil pan with a siezed bolt.
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
