(Finally) I refuse to install another auto trans
Old 12-05-2014 | 02:53 PM
  #81
richardparker's Avatar
3.7L Nitrous Breathing CL
Locksmith still hasn't showed up yet.
Is it true I can somehow pop the Auto ecu,key and ignition back in to see if it will start ?
Just read that somewhere to leave a plug out and it will start.
Old 12-05-2014 | 06:19 PM
  #82
yungone501's Avatar
J-series addict
This is not true. Not without the auto trans harness plugged in as well. You must also jump several circuits to trick ecm into thinking the range sensor is in park/neutral.
Old 12-05-2014 | 07:24 PM
  #83
rockstar143's Avatar
All I can say is that you just confirmed that I'd never attempt something of this magnitude. I appreciate the effort, and you sharing the frustrations...always good to read and I give you props for the size of your sack.
You must live in a relatively rural area...the city would be out in a day if I did that on my sidewalk!
Old 12-05-2014 | 07:29 PM
  #84
brian6speed's Avatar
Lone Wolf
What makes it difficult is RP started with a CL-P instead of a CL-S.
Old 12-05-2014 | 07:31 PM
  #85
I'm totally ignorant...so I'm guessing that makes it 10 times harder, huh?!?
Stating the obvious would have been swap auto back in, sell for what you can get and jump on a 6MT for sale?! I'm guessing they're hard as heck to come by?
Old 12-06-2014 | 12:27 AM
  #86
yungone501's Avatar
J-series addict
Richards far too stubborn to turn back now. I don't foresee a white flag appearing in his thread anytime soon.
And yes, the Type S models are much different from the base models. The powertrain mechanics and electronics have similarities but unlike the 3g TL's, the wiring isn't easily modded to accommodate various swaps.
Old 12-06-2014 | 01:57 PM
  #87
No white flags here.
Frustration, Yes,lots of it.
The locksmith never showed. Today I called around to everyone in my area and they all seam to think it can not be done and wont even attempt to come over because its not what was in the car to begin with.
I guess I'll wait till every wire and every piece of the 6speed car is in my car then deciede if its getting towed to Acura or buying another ecu set or whatever.
Dont know what would be the right way to go about this.
I dont have the vin or key code for the 6 speed stuff but I have the key code for my clp stuff.
Could they program the 6speed ecu to match the clp ignition+key since I know the pin/key code for that?
I dont know.
Would honda be able to do it? There is a honda dealer only 5 miles from me?
teh CL (01-21-2015)
Old 12-06-2014 | 03:45 PM
  #88
Karanx7's Avatar
Unregistered Member
Honda can do it. If all else fails, I can loan you my 03 CL-S6 ECU and key.
Old 12-06-2014 | 08:26 PM
  #89
yungone501's Avatar
J-series addict
It shouldn't be that difficult to find a locksmith capable of programming the key. Google "mobile programming" or "auto programmer" and make sure you include your city/state in there as well. Craigslist is another good place to find a mobile programmer. Lastly, try and keep your details/explanation of whats simple as most programmers don't like to mess with swaps or projects due to issues commonly interfering with their ability to do their work. I speak from experience and deal with a few regularly.
Old 01-20-2015 | 06:05 PM
  #90
Contact.
The car is finally running with help from a TVrepair man switching imoblizers from my auto eecu and a lead from another member to do so.
CL-Future (05-14-2015)
Old 01-20-2015 | 06:19 PM
  #91
Lone Wolf
congrats
Old 01-20-2015 | 07:50 PM
  #92
gnuts's Avatar
3.5 psi
nice! can't wait for pics and videos!
Old 01-21-2015 | 04:53 PM
  #93
ahxChun's Avatar
Dharma Member
congrats
Old 01-22-2015 | 08:27 AM
  #94
AnthraciteTypeS's Avatar
6mt swapped..smart
Grats RP. In for pics/vids
Old 01-22-2015 | 02:57 PM
  #95
No limp mode.
I think my pos 90mm tb is leaking vac.
I can't get the rpms under 900 at idle.
I'm working a lot lately but this weekend I'llbe on it.
http://s899.photobucket.com/user/acu...q5emf.mp4.html
Old 01-22-2015 | 06:45 PM
  #96
Lone Wolf
That TB seems like more trouble than it is worth. Is a 76 MM b series TB not big enough? Would think exhaust is probably the restriction.
Old 01-25-2015 | 01:00 PM
  #97
Up and down the street 1st threw 3rd.
Clutch is grabby trying to drive normal.
I got to get use it the pucked disc.
teh CL (01-25-2015)
Old 01-25-2015 | 07:38 PM
  #98
ahxChun's Avatar
Dharma Member
P2r disc?
Old 01-26-2015 | 10:03 AM
  #99
6mt swapped..smart
I had a p2r disc and it was a nightmare. Reverted back to stock clutch shortly after. But you probably need something beefier than stock if you still plan to spray
Old 01-26-2015 | 03:19 PM
  #100
Lone Wolf
I would think the self adjusting PP is the weak link.
Old 05-05-2015 | 06:13 PM
  #101
Today I did a little beating on the car since the swap.
At one point I tried to do a stationary burnout without dumping the clutch.
I pulled the ebrake and let the clutch out semi aggressively I guess ,at about 4k. Smoke was pouring car did not stay put.
As I was watching the smoke pouring I forgot to let the ebrake off and dragged the rear tires atleast 150ft and half spun the car. As soon as I noticed it was wanting to spin I got on the brakes and ended up 10ft from a pole with my bumper.
whoopsie, Either way it was fun.
apparently not use to the whole ebrake thing yet.
Old 05-06-2015 | 09:24 AM
  #102
fsttyms1's Avatar
good way to flat spot the tires too
giovane
2G RDX DIY & FAQ
07-08-2016 11:46 PM
redman333
10-09-2015 11:12 AM
proxus
09-16-2015 07:18 PM
Skirmich
09-15-2015 07:41 PM
