Which is faster CL-s or TL-s ?
the name says it all
wrong!!!
actually he is not....the tl-s with navigation..weighs like 400 more pounds than the cl-s so the tl has more hp but the weight makes the cl faster!!!!
Any Lady Want One??? :-P
I thought I read somewhere that a TLS and CLS went head to head a couple of times and were pretty much even. The CLS won half the time. TLS won (guess what) the other half I think the CLS won by a hood length. Not sure though
Re: Re: wrong!!!
Originally posted by TypeSAddict
Where is it that you get your crack? :P
well mathematically speaking, you would need to have 289 hp to make up for 400 lbs. However the navi only adds like 20 lbs (it did for the 2000's), and the tl is about 100 lbs heavier than the cl. Thus, the cl should technically be faster only by a hair.
Re: wrong!!!
Somebodies Smokin Something here ! ?
You just Pull that outche BUTT ?
260HP For Both CL-S & TL-S
whatever!!!
whatever the cl-s weighs 3470 and the tl-s weighs 3574 so even if they did have the same hp the cl would still win because that little bit of weight would make the whole difference!!!!...duh it is common sense!!!
Re: whatever!!!
13 Second CLS Defender :)
Realistically this comparison is the same car against itself...
Same Engines
Same Transmissions
Same Basic Drivetrains
The weight is really barely worth noting as a contributing factor since the standard deviation within the same car is no greater or less then between any two runs among the CLS vs TLS. This is one where driver skill (launch) and luck really dictate the winner.
Same Engines
Same Transmissions
I had heard the following:
THe TLS weighs ~20 +/- more than the comprably equipped CLS
The TLS was tested to be .5 sec faster 0-60 by MT (could have been two diff drivers etc, any .5 diff is considered negligible by these magazines)
I aslo heard (don't give me shit) that the only difference between the two is the way hte spark plugs fire (firing order) and some from the TL site seem to think that is why it is faster. I don't see how this is possible.
So I'll just add to the hype... again, just info that I have heard.
Floyd Mayweather Jr.
Same Engines
Same Transmissions
Same Engines
Same Transmissions
i heard the TLS is going to come out with a passive pure oxygen injection system. PPOIS for short, it is a mod that significantly increases horsepower to the wheels by creating more pressure.
Pretty soon us TLS owners will be kicking your assees all up and down local highways.
Location: Somewhere between here and there, yet neither.
Originally posted by moomaster_99
This is a stupid thread...let's lock it...neither is faster. End of discussion.
I was going to buy a CLS and then I saw the TLS and was like wow, I can fit more girls in the back seat, then off to the bedroom I went.
But Really guys come on, do you really think that you can hang with POIS??? it is obvious our car is better
In order for you guys to understand the PPOIS you must first understand the basics of FLUX!
Graduate work on this course can be done on flux capacitors. Hence, the creation of a machine so bad it could leave flaming fire tracks and go 0-88 in 10 seconds!
MetalGearTypeS
08-29-2016 08:28 PM
rcs86
08-02-2016 06:52 PM
RSpyder
09-30-2015 12:46 AM
