the famous squeak
Old Jan 16, 2005 | 04:38 PM
blackdog's Avatar
the famous squeak
I did a search and found some older discussions about front end squeaking but no "for sure" answers. I have 35K miles on an 03 6MT CLS. The squeak occurs with each turn of the steering wheel. When the car is parked I can replicate the sound by pushing on the driver's side front fender.
One clue: the dealer put new rotors on the car last month.
Any ideas of what to look for would be appreciated. I always like to tell the dealer what is wrong before they start ripping parts out!
Thanks,
Blackdog
Old Jan 16, 2005 | 07:11 PM
Slimey's Avatar
Where is my super sauce?
Bad strut? Does the corner bounce a lot when you push on it? Is the strut leaking oil?
Or -- Something loose on the suspension/steering rack after the brake install. Jack it up, pull the wheel and give the whole suspension a good shake and see what's loose.
Old Jan 16, 2005 | 08:18 PM
wheelmanII's Avatar
been there
lower ball joints- had mine done last week under warrenty at 36k bad squeek
any trouble in 3rd gear with MT6- i have a chatter- even after new clutch-
2 others in town have same mysterious chatter- no diagnosis from dealer other than characteristic if car- straight from acura
Old Jan 17, 2005 | 05:25 AM
187_FAQ's Avatar
newbie
hmm.. i have that exact problem, but i have coil overs. i was thinking mine sqeak because i need to wd40 them.
Old Jan 17, 2005 | 05:26 AM
187_FAQ's Avatar
newbie
try wd40
Old Jan 17, 2005 | 11:40 AM
ga2000's Avatar
1/4 14.4 at 95
my car is having the same problem .i have 17,800 miles on my car . what can the problem be .
Old Jan 17, 2005 | 12:53 PM
brianlin87's Avatar
ASM I.S. Design FTW.
Originally Posted by 187_FAQ
try wd40
lol
Old Jan 18, 2005 | 09:24 PM
blackdog's Avatar
Thanks for the advice. The dealer gets a look at it on Thursday, if it is anything worthwhile I will repost.
Blackdog
Old Jan 19, 2005 | 06:05 PM
craigwilloughby's Avatar
I had the same problem, and the dealership said they tightened bolts on the sub frame. Who knows if thats BS or not. I haven't heard the squeek in 25k.
Craig.
Old Jan 20, 2005 | 05:25 PM
blackdog's Avatar
yup, it was the ball joint, part not available, repair scheduled for next week
Blackdog
Old Jan 21, 2005 | 03:25 PM
carquest's Avatar
chatter problem........
i have the same shatter probelm in 3rd, 4th, & 5th. sometimes 2nd. had the problem since about 500 mi. have 8K now. i have also been told that the problem is due to acura's ass-hole engineers insuring that this trans is the shittiest design on the market. nothing you can do but suffer with these cheap-ass things.
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
forrie
Sep 15, 2015 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
Aug 30, 2015 02:39 PM
