A/F ratio gauges
Old May 23, 2003 | 02:56 PM
jucee187's Avatar
PACDAT
A/F ratio gauges
Do these gauges determine/displays whether your car is running lean or rich? is it beneficial to have when running nitrous to go along with the nitrous bottle pressure gauge?
Old May 23, 2003 | 03:00 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
The best is to get one the connects to O2 sensor!
Old May 23, 2003 | 03:10 PM
jucee187's Avatar
PACDAT
which ones have that feature? how about the autometer a/f gauge?
Old May 23, 2003 | 03:20 PM
Happy CL-S Pilot
This one:
Old May 23, 2003 | 03:31 PM
allmotor_2000's Avatar
They don't help you unless you have a wideband O2 sensor!!!
Old May 23, 2003 | 03:35 PM
Happy CL-S Pilot
Please could you explain why the stock is not good enough? I am not expert, but if the O2 is good for the Acura Engineer ( NA) why it is not good enough?
Old May 23, 2003 | 07:27 PM
ModAddict's Avatar
It's only a narrow band, accurate at a stoich, (14.7:1), which is good for the environment, but not performance. I'm not sure how narrow it is, but for example, it might be something like 13.5-15.5 to 1, and ouside of that it's not accurate at all. Here is an inexpensive wideband set up. Some where on this site explains it better. http://techedge.com.au/vehicle/wbo2/default.htm
Old May 23, 2003 | 07:38 PM
types1967's Avatar
dont get the a/f guage i disconnected it since it screws up the voltage going to the computer.our sensors are very delicate and does not like voltage variations which the guage causes.i had pinging issues and since i removed it it was gone.anyway its not accurate so stay away from it trust me first hand experience.
Old May 23, 2003 | 08:27 PM
ModAddict's Avatar
I have the Tech Edge wideband unit and and O2 sensor I planned on using in a second o2 bung before the cat, with the blower setup.
I just noticed on the site it has a "Narrowband output (with adjustable stoic point) provides sensor signal for ECU."
If I adjust the stoic point to say 12:1, won't this trick the ecu and change the entire fuel map? Might this help with the lean condition Scalbert experienced with the high boost pulley?
Old May 23, 2003 | 08:34 PM
ModAddict's Avatar
Here's another quote from the site.
"The version 1.5 WB unit has a narrowband output and, with care, it can replace the existing narrowband sensor you may have, but note that you run the risk of damage to your vehicle if you run very rich or very lean mixtures for extended periods of time, or for very short period of time on forced induction motors, incorrect mixtures can rapidly cause damage."
Now this makes me think I can richen things up with this unit, and the ecu will think all is well!
Old May 23, 2003 | 08:36 PM
The lean condition is really not the ECU... its the limitations of the stock injectors!
Old May 23, 2003 | 08:47 PM
ModAddict's Avatar
Add bigger injectors?
Old May 25, 2003 | 12:21 PM
jucee187's Avatar
PACDAT
complicated..
Nashua, did you have any of the problems TypeS1967 was experiencing? TypeS, could it be that it was an install error?
So allmotor, how can i be able to tell if my engine is running rich or lean when using Nitrous? im only doing a 55 shot so will there EVER be any chance of me going lean?
Modaddict How much is the wideband O2 sensor? and how difficult is it to install?
Old May 25, 2003 | 12:27 PM
numbaonexstunna_RENAMED's Avatar
mine looks like its workin fine.......i duno
Old May 25, 2003 | 12:57 PM
Happy CL-S Pilot
Re: complicated..
I don't have any A/F meters at all.
Another option is to use a real-time OBD-II Scanner to read theO2 sensor values. like this oone:
Old May 25, 2003 | 09:18 PM
ModAddict's Avatar
Re: complicated..
It was under $400, including the wideband sensor from the Parts Bin. Go to this site, it's all there. http://techedge.com.au/vehicle/wbo2/default.htm
I haven't installed it yet, but there's not much to it.
Old May 26, 2003 | 08:17 AM
jucee187's Avatar
PACDAT
NUMBAONEEXSTUNNA. did you have to use the wideband o2 sensor? and which a/f ratio gauge did you use and i cant tell in the pic.. or are you referring to your v-afc?
Old May 26, 2003 | 09:50 AM
naw i dont have the wideband o2 sensor.......
i put in the autometer sport-comp a/f gauge
Old May 26, 2003 | 10:19 AM
jucee187's Avatar
PACDAT
numbaoneexstunna. so you have 2 a/f gauges 1 vafc and autometer. do you have day time pics? i want to see where you mounted it.. the vafc does the same thing right? it displays the a/f ratio but the difference is you can change the settings and change VTEC engagement.
can anyone confirm this?
Old May 26, 2003 | 10:56 AM
vafc doesnt show air/fuel ratio...... u just tune with it
i just have it sitting there cuz i havent decided where to mount it.
Old May 26, 2003 | 11:03 AM
jucee187's Avatar
PACDAT
numbaone.. y dont you get the pillar gauge pods?.. arent they universal fitting?
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Billu99tl
Sep 13, 2015 11:30 AM
