F/P and boost.
Old Aug 17, 2005 | 07:12 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
F/P and boost.
This has been an on going problem. the car doesnt seem to be running bad or pinging but my FP gauge is reading 38 lbs when the engine is cool @ idle and drops to 30-32 lbs when warmed up @ idle I remember the FP being higher especially at WOT. It would go over 100, now it is going about 98 LBS.
The boost is a diffrent story. no matter how tight i make the belt the boost still goes from 4.5 lbs to 2-3 lbs @WOT, as if the belt were slipping. I also have the hight boost pulley. shouldnt the boost be at least 6 LBS? yesturday I installed the B-pipe and I thought that would help because prior i had a shitty custom exuast on there. how can I get this belt to stay grippy and most of all what am I going to do about this FP. I remember the S/C being a lot quicker for some reason.
something just doesnt seem right.
Thanks guys
Old Aug 17, 2005 | 07:27 PM
italiaCLs's Avatar
Old Aug 17, 2005 | 07:52 PM
italiaCLs's Avatar
Old Aug 17, 2005 | 10:03 PM
italiaCLs's Avatar
please.. some one help!
Old Aug 18, 2005 | 07:40 AM
scalbert's Avatar
The fuel pressure sounds fine at idle when warm. However, if the boost is dropping so will the fuel pressure.
One thing to check is the bypass valve. With the engine running get under the hood and manually blip the throttle while watching the bypass valve on the blower. It should rotate about 90 degree with a quick and serious throttle application.
However, it sounds like belt slippage though. Have you tried changing belts? That may be a start. Also, how are you tightening the belt?
Old Aug 18, 2005 | 10:06 AM
ThinJim's Avatar
Thanks guys
Hey Italia-
How are you doing? With regards to your problem, I'm wondering if the larger catback pipe and the elimination of the resonator "can" (the small muffler directly behind the cat) you've installed has anything to do with it. I know you had a cheap one installed after the initial installation of the blower. Did you have higher boost before the larger diameter exhaust? If you reduce back pressure the front of the engine breaths easier. Anyone have thoughts on this?
Old Aug 18, 2005 | 10:25 AM
italiaCLs's Avatar
Hey Tom, how ya doing. I did have a crappy pipe on there, but now i have the b-pipe which is supposed to be better. no custom stuff. the boost is the same after I put it on. so is the FP. I just dont know what it could be. the boost just isnt pegging at 6 LBS its going to 4.5 the slowly going down as the RPM's climb. I am begining to wonder if it is that custom alluminum tension pulley that MCA made for me. The harmonics are diffferent in the alluminum one then they are in th estock plastic one tha comptech provides. I have the stock one and i'm going to try to put it on to see if there is a difference.
Old Aug 18, 2005 | 10:37 AM
scalbert's Avatar
Completely opening the exhaust wouldn't drop the boost this much. I went from almost 8 to 7 PSI when I opened my cut-out. Plus, it shouldn't trail off as the revs climb with the PD blower. I would look to belt slippage.
Old Aug 18, 2005 | 10:54 AM
mrsteve's Avatar
Sounds like a stretched belt
Old Aug 18, 2005 | 11:09 AM
italiaCLs's Avatar
might be. hope it is. you dont thinnk it is the pulley?
Old Aug 18, 2005 | 11:10 AM
mrsteve's Avatar
That's also a variable thrown into the problem. Since you aren't using the factory belt tensioner it could be a problem. What belt are you using? Gatorback? What size?
Old Aug 18, 2005 | 11:24 AM
Smitty's Avatar
aren't you the guy who sprayed the belt with WD40 because it was squeeling?
Old Aug 18, 2005 | 12:13 PM
italiaCLs's Avatar
no i did not do that, that was someone else.
Old Aug 18, 2005 | 12:17 PM
italiaCLs's Avatar
just got off the phone with comptech. they said to use a gatorback #4040252
it will have more grip and not have to be tightend as much. i guess ill go try that belt. I will also put the stock tension pulley on. hope it works.
Old Aug 18, 2005 | 12:19 PM
mrsteve's Avatar
What belt do you currently have on there? Don't say Dayco That belt lasted all of about 7 days on my car.
Old Aug 18, 2005 | 01:22 PM
Smitty's Avatar
yeah, ONLY use Goodyear Gatorback belts... took me 3 days to find one... I paid like 17.00 for it...
If your smart you will pick up 2.. I have an extra belt, just in case.
Old Aug 18, 2005 | 01:41 PM
mrsteve's Avatar
Old Aug 18, 2005 | 01:55 PM
Smitty's Avatar
call me stupid.. ha.... You learned everything from me... and I learned everything from Scalbert..
Old Aug 18, 2005 | 02:22 PM
mrsteve's Avatar
Old Aug 18, 2005 | 03:23 PM
ThinJim's Avatar
Hey Dan, I guess those belts are the sticky wicket and need routine adjustment with the HBP. Let us know how it works out. C-Ya
Old Aug 18, 2005 | 03:54 PM
italiaCLs's Avatar
well i went to the auto store and they didnt have any of those goodyear belts. It turns out the the belt that was on there was a goodyear gatorback but I still think its to big. I have to go with the one I had originally on the car. the car worked great then. any way I replaced the alluminum pulley with the stock comptech one an d it is better already the boost isnt droping as much but the FP is still low. I think with that new belt all the problems will be solved I hope. I just remember when I first picked up the car, the boost was pegged at 6 LBS and I didnt even have to floor it for the FP to go to 100 plus LBS. just for the record does anyone know what size belt I should use with the H/B pulley. Thank you all.
Old Aug 18, 2005 | 03:58 PM
Smitty's Avatar
no need for a new belt when upgrading any of the pulley's
I can not spell or think today..
Old Aug 18, 2005 | 06:12 PM
You can get the gatorback #4040252 on-line at Autozone.com. They get you on the shipping though.
I stopped by one (Autozone) near my house on Saturday and they had it by Tuesday. ($12.99 +tax)
As mentioned, it's a good idea to carry an extra belt just in case.
Old Aug 18, 2005 | 06:34 PM
italiaCLs's Avatar
yeah. Why do you think the belt I have now wont tighten? could it be stretched?
Old Aug 18, 2005 | 09:06 PM
mrsteve's Avatar
I'm assuming you have autometer gauges? Call autometer and speak to the tech department. Ask them what voltage coresponds to what fuel pressure reading. I had a fuel pressure sensor go bad on me. Started out just the same way yours is now. FYI replacement sendors are $100.
Old Aug 18, 2005 | 11:41 PM
italiaCLs's Avatar
makes sense but why would both meters be acting like this? both boost and FP. i hope not both are bad.
Old Aug 19, 2005 | 06:49 AM
scalbert's Avatar
Slipping belt and/or a failing FPR which is certainly not unheard of.
Old Aug 19, 2005 | 08:11 PM
italiaCLs's Avatar
i can i tell that it is the FPR that is bad?
Old Aug 19, 2005 | 10:26 PM
scalbert's Avatar
Get the boost straightened out and then we can take the next step.
It is all about process of elimination.
Old Aug 20, 2005 | 09:36 AM
italiaCLs's Avatar
gotchya. i just need to find a new belt.
Kramer1
Mar 12, 2008 07:22 PM
MattTSX06
Jan 21, 2006 07:54 AM
scalbert
Apr 16, 2003 06:50 PM
SiGGy
Nov 21, 2002 03:30 PM
