(Extremely crappy) Track Results
Went to the track tonight and got in 7 runs in 80 minutes!! The results are generally piss-poor, IMHO and very inconsistent with the last time I ran my car.
Here are some of the runs.... Temp was 85-92 degrees, low humidity. I get home and watch the news to find out we had a freakin' record high of 98 today
First Run
R/T - .915
60' - 2.427
1/4 - 15.498
MPH - 88.71 (seems AWFULLY low??)
Worst Run
R/T - .973
60' - 2.409
1/4 - 15.511
MPH - 88.39
Best Run
R/T - 1.149
60' - 2.334
1/4 - 15.167
MPH - 90.10
R/T - 1.138
60' - 2.381
1/4 - 15.415
MPH - 92.19 (this is more like it!!)
R/T - .911
60' - 2.352
1/4 - 15.380
MPH - 89.24
R/T - .912
60' - 2.325
1/4 - 15.305
MPH - 89.23
R/T - .855
60' - 2.399
1/4 - 15.287
MPH - 92.72
Question #1 - Why are my trap speeds all over the freakin' place and why are they so LOW? When I went to the track last May, I made 5 runs. The ET and trap speeds were relatively consistent compared to tonight. They were as follows:
15.224 @ 92.34
15.535 @ 92.94
15.222 @ 92.05
15.027 @ 93.19
15.421 @ 93.68
The only thing that made me feel better is EVERYONE seemed to be running slow. Check these times out...
2002 Maxima SE 3.5 auto - 15.6 - 15.9!!!
1st gen Acura NSX (5spd) - 14.5 - 15.0!!!
Glad to know I'm not the only shitty driver in town!!
First Run
R/T - .915
60' - 2.427
1/4 - 15.498
Worst Run
R/T - .973
60' - 2.409
1/4 - 15.511
MPH - 88.39
Best Run
R/T - 1.149
60' - 2.334
1/4 - 15.167
MPH - 90.10
R/T - 1.138
60' - 2.381
1/4 - 15.415
R/T - .911
60' - 2.352
1/4 - 15.380
MPH - 89.24
R/T - .912
60' - 2.325
1/4 - 15.305
MPH - 89.23
R/T - .855
60' - 2.399
1/4 - 15.287
MPH - 92.72
15.224 @ 92.34
15.535 @ 92.94
15.222 @ 92.05
15.027 @ 93.19
15.421 @ 93.68
I'm not a member on Maxima.org but can you post our threads mine and marks oh and let those homos know I don't have a Type S hahahah so there SE runs like a CL hahahah. Oh and they didn't run 15.5 they ran 15.8 and 15.9
Sounds like fun guys! What's the elevation there? How did the Kumhos work out? Any problems w/wheel hop? What psi did you run your tires at? Nice runs by the 2002 max :P
Honkey
Sorry I didn't get back to you guys...I was watching 3 guys spend 2 hours trying to mount my tires then I had meet my sister for Dinner. We should organize something again soon. Later.
-Aaron
-Aaron
Retired. Not available.
Re: (Extremely crappy) Track Results
Damn, you still havent broke into the 14 with intake and header? Man, is something wrong with your car? I'm sorry that you have that low trap speed and high ET.
1 Post
Re: Re: (Extremely crappy) Track Results
I hope to see 14.8.... we shall see.
Jim
I have a ticking noise from my engine which means I need my valves adjusted which I'm planning on doing at the 30k service (now at 27k). I don't know if that's enough to make a difference but something seems wrong.
Hmmm...oddd that the traps woud be that inconsistent.
Were you having traction issues? Normally, bad traction in 1st will not hurt you trap, but if you were spinning way out to the 330, it could hurt the trap. I doubt that is the case, though...
What were the 1/8 traps on the runs?
here are the 1/8 traps to go with the 1/4 traps:
72.74/88.71
72.56/88.39
74.47/89.24
74.25/92.19
73.21/89.23
74.35/92.72
74.03/90.10
I looked back at my runs from last May and the 1/8 traps were all 73-75mph.
That's wild. I can't think of a good reason that you got those results.
Runs 3 & 4 are the most telling (or baffling) a 15mph last 8th and then an 18mph last 8th (I'm talking differential here).
Don't want to insult here or anything, but you're not lifting/braking at the first trap cone are you???
i checked all of my slips and for the most part there's a ~20mph gain from the 1/8 mile mark to the 1/4 mile. The only time it was less than 20 mph consistently was the time my headers need to be retorqued.
I'd take it back to the shop and make sure they're torquing the headers down to the correct spec.
http://www.acura-cl.com/forums/showt...threadid=51917
if so, have them apply some soapy water to the exhaust system and try to find a leak. Could the problem be w/your cai?
The thing that REALLY bothers me is that I don't know WHY I'm not in the 14s when everyone else is. There's so many freakin' factors to drag racing. I could care less that I'm not in the 14s, I just want to know a valid reason WHY!?!?!
As far as the CAI goes, I don't know what would be wrong with it. It's not making any funny noises or anything. I also check it regularly to make sure it's not rubbing on those bolts down there.
Originally posted by GoldTypeS
lol... don't worry... you couldn't insult me when it comes to the track. I am a true novice as this was only my 2nd time ever. I didn't see any "cones" at the end. There is a light at what I think is the end, and I stay on it a few seconds after that, then lift. I'm assuming the "end" is where the board that puts up the time is? Not sure if anyone who knows Firebird can confirm that. At any rate, I don't think I did anything different than the last time. But out of paranoia, I'll probably stay on it a a little longer next time!
If you are staying on it a few seconds after even the first trap light, you're prolly OK. I ususally just bring it up to 115 or so just for grins.
Wish I could be of more help, chief...
[QUOTE]Originally posted by GoldTypeS
[B]Went to the track tonight and got in 7 runs in 80 minutes!! The results are generally piss-poor, IMHO and very inconsistent with the last time I ran my car.
While I know that both your car and you are capable of doing better than that, you didn't do all that bad. I ran your best et/mph numbers thru the NHRA altitude corrector at: http://users.gibralter.net/~mhoover/...on_factors.htm
It only goes down to 1200feet, so I used a cf of .99 for our times and 1.0101 for our speeds.
Your quickest run was a 15.02, and fastest run was at 93.6mph. You're within a hair of 14's, bud.
I sure wish you guys had gone to Firebird on Saturday--I had the only Japanese car there! I got beaten like a rug by some very serious old American hardware. Not many cars there, though; I could have done 20 runs if I had wanted to.
Floyd Mayweather Jr.
I ran a bunch of 15.0-15.3's, one 14.9, and um, well, uhhh...(ahem)..a 19.4.
Speeds were 93-95. Sixty foot times were around 2.3-2.4 sec. Had some serious wheelhop on all runs.
Originally posted by Black CL-S 4-Life
Cap'n Carl are you stock?
Well, Chuck, that makes me feel better that you're barely in the 14s!!!
If you can get your wheel hop under control I'm sure you can see some 14.5s this winter. Good luck!!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
