Extended Warranty Language
Can someone please post the language on the contract for the Acura 7yr/100K extended warranty dealing with SRS? My car is in the shop with my contract.
Also, anyone have the AcuraCare phone #? Thanks.
Found this in an older post:
https://acurazine.com/forums/showthread.php?t=83966
IV._ What is not Covered:
A._ Parts other than genuine American Honda or Acura authorized parts; wiper blades; battery (except for the insight nickel-metal hydride battery) cables; belts; hoses; timing belt replacement when performed as routine maintenance: exhaust system, catalytic converter; brake system wear such as drum/rotors, shoes/pads; clutch disc, pressure plate; throw out bearing, external shift linkages; glass, body parts; body structure, panels; bright metal; sheet metal; paint; bumpers; moldings; lenses;bulbs (except for dashboard bulbs); sealed beams; fuses; weather strips (except for window run channels); outside ornamentation; wheel covers/ornaments; rims; studs; fastening/securing hardware; body seals; squeaks; rattles; buttons; carpet; dash pad; door/window handles; knobs rear mirror; trim; upholstery; electronic/audio accessories and cellular telephones other than American Honda authorized electronic/audio accessories; tires; seat belts; airbags, and the safety restraint system (except for the SRS control unit and cable reel). _ If you believe there is a defect in these parts, please contact your dealer immediately.
