Exhaust rattle after Comptech Header Install
Hey, I need some help, I have a rattle at idle when I am in Drive or Reverse. (Not in park or Neutral) I just installed Comptech Headers and when I am driving there is no Resonance, but when I come to a Red LIght or stop Sign, my exhaust completely rattles. I can get under the car and stop the rattle by applying pressure to the exhaust system. Please any input is greatly appreciated.
Originally Posted by Stealth CL
is it just the header that is ratteling? or is it under the car like the heat shield or something?
where do you apply the pressure?
so you apply pressure to the rubber hanger? is it just knocking against something like the oil pan? i really couldnt tell ya thats something youll have to look at yourself.and just find the troubled spot.
I apply pressuer to the mount attached to the A-pipe. And there are no clearance issues, is it possible that the flex joint is too stiff and is causing a ton of vibration throughout the entire system. I checked all clearance issues and there are none, so I just have no idea since I didn't have this problem before my install of the comptech headers.
that could be bro, check all the bolts and fittings, and give it some time maybe it will work itself out. other than that IDK, do you feel any difference in performance? do you have any other mods?
also with my comptech headers the hanger didnt line up right and it tore through the rubber and the hanger bar on the header would contact the metal bracket...ended up filling the bracket with window weld
now that i re read his description...it still could be either one i mentioned but probablly because of a failed motor mount...more than likely the side mount...look by the oil filter and on the inside of the engine bay accross form the PS pump...see any thing that looks like rusty water? put the car in drive and with the hood open have someone stand out side while you put the car in drive while holding the brake and reving alittle....
I had this exact same problem... the dealer replaced the exhaust hangers and checked everything. It was still there... I think it is a problem with some autos. I have an MT now and have no problem.
So... the easy fic is get a 6MT
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
k6biv
Sep 10, 2015 06:37 PM
3GTLOwns
Sep 9, 2015 09:51 PM
