esm voltage setting and fuel pressure
Old 09-29-2003, 09:18 AM
  #41
scalbert's Avatar
Originally posted by Jens H.
Ok sounds good to me .I would use the existing wiring to operate a relay .Then run some serious grade cabling to run the pump itself.
Exactly...
I planned on running maybe 4 gauge or lower with a 90 amp fuse from the battery to a distribution block in the trunk. From there I will split off with individual fuses to the amp and the pump with 10 gauge to each. I'll use the original stock power and gropnd to close a relay and for power to the pump. And obviously I try a new and larger ground for the pump.
That should provide more than enough flow path to keep the voltage up.
However, there is still one problem, I can't completely eliminate the stock wiring. I need to get into the tank without loosing a seal so I need to use the stock connector and a short bit of stock wiring.
Old 09-29-2003, 11:41 AM
  #42
retired
Jens H.'s Avatar
You can get pretty damn close to killing all of the stock spaghetti .WIth a decent seal you can even run the wiring straight to the pump .
Jens
Old 09-29-2003, 11:49 AM
  #43
scalbert's Avatar
Ya, but since the ECU monitors tank pressure I better make sure I have a good seal.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
09-14-2015 10:48 AM
HeloDown
09-08-2015 06:51 PM
braveheart
09-07-2015 08:12 AM
Quick Reply: esm voltage setting and fuel pressure
