Engine Vibrations
Old Aug 5, 2002 | 09:37 PM
Seattle Cl-S's Avatar
Blown LS6!!
Engine Vibrations
I just put the Denso plugs in my car and I think something is messed up. When I pull up to a stoplight, the car dips down in RPM and gives me that "I wanna stall" gasp. Also, the steering wheel seems to vibrate a bit more than it used to. Thoughts on what is going on? BTW, no engine lights are being triggered. HP gains not noticed.
Old Aug 6, 2002 | 07:19 AM
NSXNEXT's Avatar
Couple of things to check.
1) Make sure the plugs are gapped correctly. You shouldn't have had to change them when installed, but maybe you got one that wasn't gapped right.
2) Make sure all the plugs are seated properly.
3) make sure all the plugs are tightened properly.
4) Make sure the coil packs (plug wires) are secured and seated properly. Tighten the allen.
Other than than that, you could disconnect the positive battery terminal, resetting the ECU, then reconnect and take the car for a spin.
vpasla1
Sep 17, 2016 07:24 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Frathora
Sep 28, 2015 11:29 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
