Engine revving at idle by itself????
OK, haven't driven the CL in a while but had to replace the bypass filter. So I did that, disconnected-reconnected the pos. on the battery hoping that would reset the computer. Fired 'er up and it revs by itself from 1k-2k, over and over again. Help a
Check the idle air control on the the tb, The same thing happened to me. I removed the tb and took out the two torx screws (six point!)that hold it in to find out it was seized, I was able to get it loose with some elbow grease and wd40. I haven't had any problems since. The car was sitting for about six months in the body shop without being started.
you're suppose to disconnect the NEGATIVE TERMINAL... did you have to enter your radio code?
When you reset the ECU the car will rev. at idle because the ECU is searching for idle... YOUR CAR IS FINE... the ECU is just retraining/calibrating itself.
vpasla1
09-17-2016 07:24 PM
joflewbyu2
10-08-2015 11:16 AM
Mike Bertram
09-10-2015 09:27 AM
