Engine Idle Prob
Old Aug 4, 2007 | 06:46 PM
evilone's Avatar
COME AT ME BRO!
Thumbs down Engine Idle Prob
I was driving home from a friends house about a week ago when my engine started jumping from less than 1k to 3000k rpms. I talked to a shop and they said it was more than likely a sensor that needed to be replaced. Anyone else run into this problem? Im getting so sick all the crap that goes wrong with my damn CL.. four trannies and now this shit.. Atleast I dont have to worry about huge pot holes gown here in FL.
Old Aug 4, 2007 | 08:33 PM
fuzzy02CLS's Avatar
It's easy. First try to clean the IAC valve. Use a cleaner like gumout or similar product used to clean carbon buildup. Less then $5 at any auto parts store. It's the the sensor under the TB. It gets junked up & causes this problem. It's very common. If the cleaning doesn't work you can replace it. A new 1 is about $80 & it's very easy to replace.
Old Aug 4, 2007 | 08:35 PM
dnd2984's Avatar
If its a IDle control valve I have a used one for sale. check out the black market
SInce u are in FL I will let it go for $40 shipped
Old Aug 5, 2007 | 03:33 AM
aznboi2424's Avatar
how do you locate the IAC valve? pictures would be helpful. my engine has also been ideling weird. it pulses from 750 to 500 and back to 750 about every few seconds. when it drops to 500 the engine seem to run rough. but it does go back to about 1k when i shift it to neutral. could it be the auto tranny?
Old Aug 5, 2007 | 06:46 AM
GreenMonster's Avatar
Link is in the info thread (big orange annoucement at the top of the forum, and in a sticky too)... Since you're a noob, here's the direct link:
https://acurazine.com/forums/showthr...+control+valve
Searching for IACV or idle control valve here and on the TL forum will turn up a ton of threads...
Old Aug 6, 2007 | 01:58 AM
aznboi2424's Avatar
ok thanks
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
vpasla1
Sep 17, 2016 07:24 PM
joflewbyu2
Oct 8, 2015 11:16 AM
IlliniAcura
Sep 19, 2015 09:31 PM
Mike Bertram
Sep 10, 2015 09:27 AM
