Engine gives up
Engine gives up
Does anyone else wish that the engine wouldn't give when you are over red line. I'd like to make my own decision when to shift.
6 speed...
Re: Engine gives up
Re: Re: Engine gives up
Originally posted by tankmonkey
I sincerely hope you are kidding about this...
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Re: Engine gives up
6 speed...
Re: Re: Re: Engine gives up
A little red line never killed a car
so are you complaining about the existence of the rev limiter or are you upset that the motor doesn't continue to make decent power after the nominal redline is reached (but before the rev limiter kicks in)?
Happy CL-S Pilot
As a 6-speed the max speed for each gear should be inprinted in your head!
It is in your CLS manual...
For example, the speed at which:
1st redline at:
2nd redline at:
3rd redline at:
4th redline at:
5th redlibe at:
Read it in your manual!
1st redline at:
2nd redline at:
3rd redline at:
4th redline at:
5th redlibe at:
Re: Re: Re: Re: Engine gives up
true.
true.
1st redline at:
2nd redline at:
3rd redline at:
4th redline at:
5th redlibe at:
1st redline at:
2nd redline at:
3rd redline at:
4th redline at:
5th redlibe at:
6 speed...
Re: Re: Re: Re: Re: Engine gives up
No, I have a problem with the rev limiter. I can feel when the car has reached it's limit. I just don't like the drop in power when the limiter kicks in.
dunno why you'd have a problem with that, but feel free to bitch on.
Re: Re: Re: Re: Re: Re: Engine gives up
Originally posted by EricS
You want to shift before you hit the redline anyway. Not because of the limiter, but because the power drops off before it hits it....
Originally posted by Paul
dont u want to shift as late as possible so when u shift to next gear, it'll be in vtec already or close to there?? I shift when the needle touchs red line, then like half a sec later the car actually shifts, i think i just miss the limiter everytime
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
