Engine close to stalling when stoping...
Old Nov 27, 2002 | 03:25 PM
russianDude's Avatar
I've noticed that it happens very offten ( not every time) when I slow down to the stop or red light my RPMs drop to lke 300-400, and it feels that engine is very close to shutdown....
I also noticed this is happening in winter times more offten, is it because of this so called *winter* gasoline ?
What's the solution? Wait till spring till they get better gasoline?
I always get 93 Mobil gas....
Old Nov 27, 2002 | 03:42 PM
bkknight369's Avatar
wow 3-400? I think the lowest I usually get is like 6-700, even in the cold
Old Nov 27, 2002 | 03:51 PM
Yeah, it gets back to normal RPMs after 2-3 seconds... but during this time engine feels like its about to shutdown....
Old Nov 28, 2002 | 01:08 AM
beestea's Avatar
Mine has been doing that recently too.... that and every now and again it just idles at the first hash mark the whole time the car is running (when stopped). Turning off the car and starting it back up fixes it. Dunno whats up... im just keeping an eye on it for now.
Old Nov 28, 2002 | 01:47 AM
Nicky Pass's Avatar
Fuct in the hed!
My dealership said its because of winter gas......I know they change the alcohol content or something like that
Old Nov 28, 2002 | 02:20 AM
Seattle Cl-S's Avatar
Blown LS6!!
This might be wrong, but I noticed the "near-stall" a little after putting in the Denso spark plugs. I went back in and tightened all of the plugs and it hasn't happened since.
Old Nov 28, 2002 | 03:26 AM
FastEddie's Avatar
Wishin' I was in the Keys
Re: Engine close to stalling when stoping...
I had the same thing happen last year on my old '00 Accord Coupe with the 3.0. It turned out there was a TSB to replace the ECM. It solved the problem immediately and permanently.
Old Nov 28, 2002 | 05:43 AM
Chief F1 Fan's Avatar
check your battery connections
Old Nov 28, 2002 | 01:48 PM
GOT PSI?'s Avatar
It's Go-Time.
I've experienced the same scenario, one of the local CLS guys had his IAC replaced and it seemed to have solve the problem.
Old Nov 28, 2002 | 01:54 PM
Nicky Pass's Avatar
Fuct in the hed!
IAC=Idle Air Control....
Old Nov 28, 2002 | 01:58 PM
typeR's Avatar
theres a TSB on idle learn...during ...battery replacement ,ecu replace, or disconnected battery for 15 minutes...
Old Nov 28, 2002 | 06:31 PM
NOVAwhiteTypeS's Avatar
hmm mee too, i been noticing it for the past week. didn't pay attention to the rpm tho. but deff shutter
Old Nov 28, 2002 | 09:19 PM
AC_RENAMED's Avatar
Joe, man I told you get a new car. New G35 Coupe sure looks pimp!
Old Nov 28, 2002 | 09:23 PM
Hmn, I dont know if dealer will be able to do anything, its intermitent ... Might be every 5-10th time I stop or something like that.... And its only in winter... must be fuking winter gas....
Old Nov 28, 2002 | 10:53 PM
GOT PSI?'s Avatar
It's Go-Time.
It's not the gas.
Old Nov 28, 2002 | 11:23 PM
Originally posted by GOT PSI?
It's not the gas.
Then how do you reproduce this problem, it might not show up when I try to show it to the dealer....
Old Nov 28, 2002 | 11:48 PM
o snap its eric's Avatar
adjust your idling
Old Nov 28, 2002 | 11:49 PM
typeR's Avatar
Idle Learn
The idle learn procedure must be done on all 2003
3.2CLs at TQI so that the ECM/PCM can learn the
engine idle speed characteristics. If it is not done or
done incorrectly, the engine may have an erratic idle.
This procedure also must be done whenever you do
any of the following:
• Disconnect the battery
• Disconnect the ECM/PCM
• Reset or replace the ECM/PCM
• Remove the driver’s or passenger’s under-dash
fuse/relay box
• Remove the BATTERY (120A) fuse from the underhood
fuse/relay box
• Remove the BACK-UP, ACC (40A) fuse from the
under-hood fuse/relay box
• Remove the No. 13 CLOCK, BACK-UP (15A) fuse
from the passenger’s under-dash fuse/relay box
• Remove the PGM-FI main relay
Old Nov 29, 2002 | 12:03 AM
Hey I finally saw one of those in person the 18inch rims look fucken hot as shit w/ the brembo's
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
rklatzkin
Sep 23, 2015 04:08 PM
carz0159
Sep 20, 2015 06:11 PM
Sep 14, 2015 10:09 PM
Sep 14, 2015 03:16 PM
