Emergency Help !!!
Old Nov 9, 2007 | 04:33 PM
BlackCLS32's Avatar
INFINITY!!
Exclamation Emergency Help !!!
SO TODAY I GET IN MY CAR AND DROVE FOR A LIL BIT AND ALL OF A SUDDEN ITS STARTED TO OVER HEAT, i WENT AND GOT ANTI-FREEZE AND ADDED SOME BECAUSE THE RESIVOUR WAS LOW, THEN I WAS RUNNING ALOT BETTER. sO I DROVE DOWNTOWN, IT WAS ALL GOOD, BUT THEN ON MY WAY HOME IT STARTED AGAIN AND SO I TURNED ON THE HEAT AND IT GOT WORSE SO I PULLED OVER AND SHUT IT OFF. WHEN IT COOLED I DROVE HOME. what the fuck could it be please help
Old Nov 9, 2007 | 04:35 PM
loulinjai's Avatar
coolant leak?
Old Nov 9, 2007 | 04:40 PM
BlackCLS32's Avatar
INFINITY!!
the coolant level is high in the tank
Old Nov 9, 2007 | 04:41 PM
mrproul's Avatar
me,gill,and tl-s
thermostat
Old Nov 9, 2007 | 04:43 PM
2CLean's Avatar
Well...it's kinda fast...
Originally Posted by mrproul
thermostat
Old Nov 9, 2007 | 04:51 PM
BlackCLS32's Avatar
INFINITY!!
now second questions, is it covered with the power train warranty? my car is goin into the shop tomorrow for the new trans cause mine is fucked and it happens to be under the settlement and i have a broke center motor mount.
Old Nov 9, 2007 | 05:53 PM
rush's Avatar
03 acura cl type s
i nedd a clutch badly asap
Old Nov 9, 2007 | 06:00 PM
o1s's Avatar
o1s
i need a 6 speed cl!
probably thermostat or possible air bubble in the system.
Old Nov 9, 2007 | 06:19 PM
rush's Avatar
03 acura cl type s
i think but i have no 456 gear and theres this niose
Old Nov 9, 2007 | 06:33 PM
rush's Avatar
03 acura cl type s
wanna buy mines
Old Nov 9, 2007 | 06:48 PM
fuzzy02CLS's Avatar
Since it's going in anyway, mention it to the service guys & play dumb. They may just fix it for you.
I think they have to drain the coolant anyway.
Old Nov 9, 2007 | 08:38 PM
JohnBlayz142's Avatar
Keeping the Stealth alive
Probably a bubble or air pocket somewhere in one of your coolant hoses.
Old Nov 11, 2007 | 07:03 PM
AcuredCLS's Avatar
AcuredCLS
could definitly be a air pocket cuz if u filled it and it was ok then it sounds resonable, if its ur thermostat i dunt think you would be able to drive cuz it would keep over heating...def mention it the acura parts/service..by me the people are nice say its ur friends CL havin a problem haha.. and if it continues bring it back to acura and blame it on them tell em it was fine when u came in n now its broke hahaha
Old Nov 11, 2007 | 08:19 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
thermostat, rad cap, bubble. all possible explanations.
btw, did you fill with 50/50 mix or pure antifreeze ?
Old Nov 12, 2007 | 12:47 AM
Allout's Avatar
Blown is Best
The initial problem of being low on coolant is the concern. Could be as simple as a bad thermostat causing a boil over of coolant to a blown head gasket. Good thing it's going in.
rockyboy
Aug 4, 2024 10:35 AM
steve
Sep 30, 2015 09:23 PM
kixo
Sep 25, 2015 03:07 PM
tndirtdauber
Sep 23, 2015 03:00 PM
