is a emanage system necessary?
Old Apr 30, 2009 | 01:18 PM
p.diddy's Avatar
is a emanage system necessary for a supercharger or do you not really need it?
Old Apr 30, 2009 | 02:06 PM
gnuts's Avatar
3.5 psi
From the reading i've done you'll probably want it with the HBP. Your engine will need more fuel with the HBP and you can adjust it with that. But you could just get a fuel pressure regulator right? Also depends on what octane gas you have where you live. If you can't get 93 then you'll need it to stop detonation??
I'll let someone with s/c experience chime in...
Old Apr 30, 2009 | 02:29 PM
Nitin's Avatar
But I just got here
You don't need it with just the supercharger but definitely do with the high boost pulley
Old Apr 30, 2009 | 02:56 PM
p.diddy's Avatar
yea i got the HBP
Old Apr 30, 2009 | 03:12 PM
CL FWD SPEED's Avatar
What to do, what to think
its probably better when you safe-Tune it and get the most out of the hbp you can also just Unplug the IMRC without the e-manage for the time being and up the fuel pressure to 42psi ish if your running 93octane fuel.
here's more info on this past thread
https://acurazine.com/forums/showthr...highlight=IMRC
Old Apr 30, 2009 | 03:16 PM
p.diddy's Avatar
would i still need to unplug it with the emanage?
Old Apr 30, 2009 | 03:30 PM
No without the E-manage. Just your comptech ESM. when you tune it, IMRC is connected. Because IMRC valve opens up at 3500RPM and its a lean spot with hbp, with the e-manage tuned your compensating more fuel on that spot so your motor won't blow. remember our stock engine is already a high-compressed setup.
Old Apr 30, 2009 | 04:05 PM
gnuts's Avatar
3.5 psi
that's a great link, very informative.
Old Apr 30, 2009 | 04:14 PM
1hotcls6's Avatar
you must get tuning with hbp or say bye bye motor
Old Apr 30, 2009 | 05:06 PM
jproy's Avatar
MP90 uninstalled
^^^He knows!
Old Apr 30, 2009 | 05:27 PM
p.diddy's Avatar
is the greddy emanage blue a good buy?
Old Apr 30, 2009 | 06:19 PM
jproy's Avatar
MP90 uninstalled
It has worked well for others here. The ultimate will not work on the 6MT cars and I am trying to use something else at the moment and will let you know if it works better.
Old Apr 30, 2009 | 06:23 PM
p.diddy's Avatar
yea keep me in the loop on that. i see that you have injectors is that really necessary?
Old Apr 30, 2009 | 06:26 PM
jproy's Avatar
MP90 uninstalled
Ill tell you in three weeks
Old Apr 30, 2009 | 06:30 PM
p.diddy's Avatar
sounds good. im supposed to pick up a S/C next weekend so im just trying to get as much info as i need before i get around to installing it.
Old Apr 30, 2009 | 06:40 PM
jproy's Avatar
MP90 uninstalled
For what I am doing, probably. Ill tell you in three weeks when my car is done. The stock injectors have been run up to 12psi on a turbo, I think they were stock. 9.5psi on the blower that I know of and it worked. It’s not great though because injectors are supposed to be run at less than 70psi for peak efficiency and atomization of the fuel. You will never see a professionally built or OEM car running over 80psi on the injectors. Running injectors at 100+ psi with the stock blower pulley is pushing it. I don’t remember but I think Scalbert was at something like 130+ psi when he ran 9.5 psi and that is insane on a stock injector. If one of them froze up you would be in big trouble and wouldn’t have any time to do anything about it. I would say it is fine for up to 6psi but not ideal there either. Comptech used the 8:1 FPR to cut cost so you don't have to replace the fuel system like I did. The stockers do work and I have not heard of one injector failure. However, there are only a handful of superchargers and very, very few of those ran 9psi so who knows. I wanted larger injectors and they should have a much better spray pattern at 65psi max where I will be running them with the 1:1 FPR.
Old Apr 30, 2009 | 06:41 PM
jproy's Avatar
MP90 uninstalled
wait on purchasing the engine management! I will have some great info shortly.
Old Apr 30, 2009 | 07:29 PM
p.diddy's Avatar
i will. i want to know eveything i might need or should get to maintain my engine and tranny with a s/c w/hbp installed. i already have a tranny cooler and im planning on getting a methanol injection kit next.
Old May 4, 2009 | 10:26 AM
1hotcls6's Avatar
if you're on an auto tranny dont even bother with it
Old May 4, 2009 | 10:29 AM
p.diddy's Avatar
why is that? a lot of people have been saying if i have the hbp i will need it the s/c im gettign has hbp.
Old May 4, 2009 | 02:35 PM
nf3d0149ab's Avatar
I would get it and get a good tune.
I'm going to get one and I'm not even supercharged or turbo'd.
Old May 4, 2009 | 05:50 PM
LIPPSTUH's Avatar
Unregistered user
well from what i understand you should tune period esp with HBP or injectors.
you're adding a supercharger, it does come with EMS but that doesn't really do shit. you want more power do it right get a tune.
Old May 4, 2009 | 06:41 PM
1hotcls6's Avatar
I meant that the tranny wont last
Old May 4, 2009 | 07:45 PM
p.diddy's Avatar
it has 155,000 miles original tranny its gone this far ill take my chances. ill just get another tranny if it goes out.
Old May 4, 2009 | 08:11 PM
p.diddy's Avatar
i was going to get a tune regardless if i got the emanage or not but i am going to get the emanage.
Old May 4, 2009 | 08:51 PM
1hotcls6's Avatar
I've got an emu for sale if you want it
Old May 4, 2009 | 09:05 PM
p.diddy's Avatar
could you tell me hwat that is?
Old May 5, 2009 | 12:07 AM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
emanage ultimate.
Old May 5, 2009 | 06:43 AM
p.diddy's Avatar
thanks but im already getting a emb from a member on here.
Old May 5, 2009 | 12:37 PM
1hotcls6's Avatar
no prob
Old May 5, 2009 | 01:09 PM
SlickShiftNall6's Avatar
Quarantuning
So my friend just picked up a emanage blue for $300 for his turbo celica project. Only to find out that he needs $125 of software that can only be downloaded from greddy's site to make it work. Not to mention everything that came with it and the box are in Japanese.
Is he wrong? Can the dyno shop do it for him without the $$$?
How does this apply to our CL's? Will we need to get extra software?
I wanted to get a tune for all my bolts-ons but now I'm thinking I should go with the aem-fic. I know I only have bolt ons but every other fuel manager gets overwritten by our ecu. Any advice would be appreciated...(jproy) Thanks.
threadjack/ sorry P.diddy but you might need these answers too.
Old May 5, 2009 | 01:14 PM
p.diddy's Avatar
no prob
the emanage blue i plan on getting is coming off a S/C cl so i should be good.
Old May 5, 2009 | 01:25 PM
jproy's Avatar
MP90 uninstalled
The software is free. I forget where but there are several sites that you can download it for free including the latest updates. That shop probably doesn’t have much experience with the EM and more than likely doesn’t want to do it. Who knows There is a book in English included with the EM units, or yours is missing.
You need to have the software for a laptop to be able to talk to the EM regardless of what car you are tuning. There is no special software for the CL. It looks like the EMB, EMU, and AEMFIC are the only units that will not be overwritten on the CL/TL. However, the EMU will not work on the 6MT cars because the EMU cannot talk with the different CKP's for some reason. There are two CKP's on the CLS 6mt and only one on almost every other car out there. The EMB will work on the CLS6 but you can only control fuel. This has been used successfully by several members but I have not used it. You cannot control timing on the TL or CL with either of the EM units. We are working right now to find out if the AEM FIC will allow us to control timing but we are working against the two CKP sensors at the moment. There is one CKP (sensor B) on the back side of the clutch bell housing that reads notches off the flywheel and there is the main CKP sensor behind the crank pulley that reads off the notches on the Timing belt pulley on the crank. We should know something soon.
Old May 5, 2009 | 01:33 PM
p.diddy's Avatar
keep us posted on how it goes.
Old May 5, 2009 | 01:39 PM
thevikas87's Avatar
Your mom is in
hah yup, it already has a map on it for a auto, CLS... thats the reason I bought it in the first place!
Old May 5, 2009 | 01:51 PM
Quarantuning
Thank you jproy for the advice. I have heard of the emu not working with the 6mt cars from some of your other posts. I read all your posts btw, thanks for consistently dropping knowledge. Ok so I understand the need of the software so that the emange talks to your laptop. There is no cl specific software, and whats needed is free. Ok... I will inform my friend of this and the english manual that should have been included.
Back to the CL. The crank position sensors are your major hurdle right now in getting the aem-fic working properly. I will certainly be waiting on your results before I make a purchase of my own.
I don't plan on boosting anytime soon, do I need to adjust timing on na mods? Is fuel management enough? Will the emb be worth it ($$$) to get some gains? Its a big step. I want to make sure I get the right engine management because you need to get the corresponding harness ($$$) as well. Its a big cost to find out its not going to function properly. Thanks again.
Old May 5, 2009 | 02:19 PM
nf3d0149ab's Avatar
^ I was going to get it for bolt-ons as well...at least for now.
Old May 5, 2009 | 02:31 PM
Quarantuning
So I did some research and talked to my friend some more. In needing more software that is not included he meant the "startup cd and special cable". Sold on greddys site under emanage as the "emanage support tool" for $139. So if you can't hook up to your laptop you can't tune. I'm assuming a good tuner/dyno shop should have this already. If or when my friend buys the support tool I should be able to use it also I guess(if I get emb)
Old May 5, 2009 | 02:49 PM
thevikas87's Avatar
Your mom is in
Edit: auto, SC'ed, CLS
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
