Eibach question
Old Mar 29, 2003 | 11:29 PM
Bobbydoedoe's Avatar
I'm Cool
Eibach question
hey, i know this question has been asked many times. But if i were to go with eibach pro kit, do i need to do alignment checks? and are there any rubbing when driven? Thanks in advance
Old Mar 30, 2003 | 11:14 AM
GOT PSI?'s Avatar
It's Go-Time.
You should do an alignment no matter whcih brand of springs you install. If the spring was designed for your vehicle - then rubbing should NOT be an issue.
Old Mar 30, 2003 | 02:29 PM
Allout's Avatar
Blown is Best
GOT PSI is correct. Get your alignment checked anytime you pull apart your suspension. Also expect to do Camber kits with that type of drop.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
