ecu wiring diagram
ecu wiring diagram
Does anyone have the wiring diagram for an 01 cl s ecu? i need the 02 sensor wire so i can bypass it. i did a search and found nothing, thanks for your help
Sounds like you are trying to make a O2 simulator? Can't you just use the O2 sensor hardness (outside the car). It should be ground/power/output right? Easy to measure ground and power and the third should be output.
or you can check this site:
http://www.mkiv.com/techarticles/oxy...nsor_simulator
SUPRMN84
10-07-2015 09:46 PM
