E-manage wiring problem...
Old Jul 2, 2005 | 01:24 AM
speedr73's Avatar
You can turbo anything
Hey guys...Im sure you're sick of this stuff buy now, but I have a quick and probably stupid question for those of you who have the emanage up and running. I finally finished all the wiring, but the emanage is throwing a code...#40 Improper wiring of ignition signal wires...I have checked and rechecked my wiring and can't figure it out...The only thing I can think of now is that I have my wires backwards...When you look at the wiring diagram in the Emanage manual, it says the in wires from the harness go to the ecu...I am assuming now that the ECU is my cars factory ecu correct? If by ecu they mean the emanage then that is my problem..if not, then I have no clue...Any help would be greatly appreciated..
Oh, and the car is running fine even with this code...kinda weird I think
-Ryan
Old Jul 3, 2005 | 01:35 AM
speedr73's Avatar
Bump
Old Jul 3, 2005 | 11:26 PM
MotionEffects's Avatar
Acura TLS are SLOW
Here compare yours with this diagram which Scalbert sent me last year. This is for a TLS
Ignition
Injectors
Old Jul 4, 2005 | 01:52 PM
speedr73's Avatar
Yeah...that was the first diagram I used also...but my question was...From the emanage, in their instructions is says that the white striped wires are IN to the ECU....is the ECU in their instruction book the emanage or my stock computer
For instance...in the above diagram ( the top one) what wires are going to the letters and which ones are going towards the numbers?
Old Jul 6, 2005 | 09:03 PM
Acura TLS are SLOW
the Left side is the harness comming in from the vehicle and the right side is to the ECU
Old Jul 7, 2005 | 07:04 PM
speedr73's Avatar
Ok...thanx...looks like I figured it out...Greddy told me that you have to wire it in order of the car's firing order... So our car is 1,4,2,5,3,6...according to another post in here
Emange will be like this 1,2,3,4,5,6....will be wired 1-1 2-4 3-2 4-5 5-3 6-6
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
