E-manage ignition harness
Old Feb 13, 2005 | 03:39 AM
speedr73's Avatar
You can turbo anything
I read the emanage post here and at v6p.net, and was wondering if the 6 channels from the greddy ignition harness goes to the IGPLS1,2,3,4,5,and 6 on the stock ecu. It's the only abbreviation that makes sense to me.
Oh, and was also wondering since Steve and Brad came to the conclusion to leave the VTEC alone, do I still need to wire it up or just leave it be?
Old Feb 13, 2005 | 09:31 AM
speedr73's Avatar
Forgot, since mine is 99, I am DIS so would that be only one connection instead of all six?
I am making myself a little confused here...
Old Feb 14, 2005 | 06:12 AM
scalbert's Avatar
You do have a distributor, correct?? Do you have the shop manual for your year car??
Old Feb 14, 2005 | 06:50 AM
speedr73's Avatar
Yes, I verified this because when I first install the emanage, the rotary settings were the same as you, but then I realized that I am 6cyl. distributor. So my settings are 5-8-D
The manual that I have is for the 98-99 Accord V6...should be the same, but I am gonna try and find a helms.
So everything is running fine for the initial install, but nothing is wired for the ignition harness yet
Old Feb 14, 2005 | 07:43 AM
scalbert's Avatar
Do you know which ECU pin is the ignition coil signal??
Old Feb 14, 2005 | 12:47 PM
speedr73's Avatar
Yes...I know all the pin number correspondents, but that is where I get confused...Do I use the IGP2 or IGPLS? The list I printed out from 99%stock from v6p.net says there are 6 different channels for IGPLS with 6 diff. pins. Only other thing would be IGP2, IGP1 is used for power. He said this list is for the 99TL, and I verified the number of IGPLS wires to the manual I have(98-99 Accord V6)
Old Feb 14, 2005 | 12:50 PM
scalbert's Avatar
IGP2 is the switched power for the ECU. IGPLS sounds like the correct lead. Give me a minute and I will look into the matter.
Old Feb 14, 2005 | 01:16 PM
speedr73's Avatar
my bad, it was vtec-v6 that posted it...here it is if you want to decipher which one it could be...other than IGPLS, I wouldn't come close to knowing which abbreviation it is, and if it is, why are there 6?
http://www.v6performance.net/forums/...ad.php?t=19596
Old Feb 14, 2005 | 01:47 PM
MotionEffects's Avatar
Acura TLS are SLOW
Scalbert is always on top of things
Old Feb 14, 2005 | 01:49 PM
scalbert's Avatar
Now remind me again, what year and car do you have??
Old Feb 14, 2005 | 02:18 PM
speedr73's Avatar
99tl
Old Feb 14, 2005 | 02:26 PM
scalbert's Avatar
Then it is the same as the '00+ AV6 which is the same as the 5AT CL-S.
http://www.flwse.com/images/steve/Co...ge/5AT_31P.JPG
http://www.flwse.com/images/steve/Co...31P_Manual.jpg
Old Feb 14, 2005 | 02:37 PM
speedr73's Avatar
So I have to tap into each one? This is where I get confused...I thought I was Distributor, not coil on plug. I need to verify which one I am. From this info it looks as if I am coil on plug and need to switch my rotary setting back to 7 for coil on plug.
Old Feb 14, 2005 | 02:40 PM
speedr73's Avatar
Ok, I just called acura...They said the 99TL is coil on plug...don't know where I got DIS from...this info will help a lot.
Thanks Steve.
Old Feb 14, 2005 | 02:41 PM
scalbert's Avatar
Yep, you should be coil on plugs and are correct on all signals will need to be intercepted.
scalbert's Avatar
don't know where I got DIS from....
DIS is coil on plug in our case, Direct Ignition System, aka, non-distributor.
Old Feb 14, 2005 | 02:47 PM
speedr73's Avatar
OH...I am retarded, I thought you guys were abbreviating distributor...that could have been bad.
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
malvothegreat
Sep 29, 2015 12:38 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
