e-brake wiring path
Old Jan 18, 2006 | 06:02 PM
03_CLS_6sp's Avatar
Question e-brake wiring path
I'm wondering if anyone with a wiring manual can help me out.
I want to install a DEI 452T to control my door locks like I did in my Accord towards the bottom of page one. The 452T will allow the door locks to lock and unlock with the emergency brake.
What I need to know is the color of the wire (I think the Accord was Green w/Orn stripe, and three silver dots), and which connector the ground signal from the emergency brake switch goes into the kick-panel cluster.
With this info I should be able to install the unit without wires running all over the place. This time I'll take pictures, in case there's interest.
Thanks in advance.
Old Jan 18, 2006 | 09:48 PM
MeaghanA's Avatar
Limited answer.....
My oem book shows grn/red from the p-brake switch to the mux. No info on pin id. at the mux junction. This circuit is also in parallel with the brake fluid float switch which may be easier to trace.
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
