e brake indicator light on in the AM
Yeehaw
every morning the indicator light for my e-brake is on. the brake is definitely not engaged at all, but the light in the dash stays on for about the first 15 minutes or so of my morning commute.
is that bad? why would that happen? do I need to do anything about it?
Yeehaw
Originally Posted by sgmotoring
It is a bad brake master cylinder float.
yep.
dealer fixed this when I had it in there for something else.
check your fluids and tap around and if that doesn't work stop by the dealer.
Doin' da crack shuffle
Originally Posted by anothercls
Old old threads, again....wierd.
Not wierd.
I did a search 'cause I had this same problem this morning and I remember seeing a thread about this. I wanted to know the solution.
Sweet as Gold
Umm...if the fluid is low don't just top it off and walk away. CHECK UR BRAKE PADS.....the only way for brake fluid to become low w/o leaking is low brake pads. when ur pads get low the piston moves further to compensate for the low pads...when the piston moves further more brake fluid fills in the lines causing low fluid. If u replace the brake pads and compress the calipers back to normal form to fit the new brake pads in...ur fluid will rise again.
Since I've had my car, I've been trying different brake pads to see which ones i like the best. I've tried every set from Axxis to EBC. I even upgraded my rotors. Problem was I never flushed the brake lines. I never even looked at the brake fluid. My dad (he's a mechanic for Chrysler) told me to get my brake system flushed and go from there. I got an appointment this Sat. and the dealer said they would check out the master cylinder when they flush the brake lines. I'll keep you guys posted.
Sweet as Gold
becareful...cause I've heard many stories about dealers not actually flushing the lines. They just replace the fluid in the master cylinder resevoir and you'll never know. Make sure that u can trust them.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
