Dyno guys..does this work?
Old Sep 7, 2003 | 09:38 AM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
I was just watching HorsePower TV and they had a product that works on imports/domestics 96+. has two cables and plugs into your own PDA. THe cost of the hook ups and software was $350, but claims to do a dyno of your engine right there and eliminates the use of a dyno machine.
Any thoughts?
Old Sep 7, 2003 | 10:12 AM
SiGGy's Avatar
Moderator Alumnus
yes, its fairly accurate if it's the one which monitors RPM and you dial in the weight of your vehicle.
Here's the older version of it. I assume this new one uses ODB-II to get the readings instead of the inductive pickup.
Keep in mind you *have* to weigh your car. Can't guess, or these devices are not accurate.
http://www.charm.net/~mchaney/homedyno/dynokit.htm
Old Sep 7, 2003 | 02:43 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
raptorlCLS: what's the comptuer one you were talking about?
Old Sep 7, 2003 | 07:11 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Not that acurate.. data rate of OBD-II is slow, not real time. if you have tire spin what do you do?
Accelerometer based is better.
Old Sep 7, 2003 | 08:31 PM
RaptorCLS's Avatar
PDA DYNO
Whether your street machine is an import or domestic, if it’s a 1996 or newer you can dyno the motor right in the palm of your hand. With Noxology’s PDA-DYNO you can measure horsepower, torque, zero to sixty times, fuel economy and drag strip performance. Using their adapter, you just connect your personal organizer into the diagnostic port of your car’s computer, and the information will be displayed on your LCD screen.
Phone: 800-NOLOGY1
URL: http://www.nology.com
Old Sep 7, 2003 | 08:59 PM
Red Rider's Avatar
Subie Dubie
For less $$ you can get the G-Tech Pro Competition ($249) It does the same thing based on weight and rpms.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
