Dyno guys..does this work?
Dromaeosaurs/Velociraptor
I was just watching HorsePower TV and they had a product that works on imports/domestics 96+. has two cables and plugs into your own PDA. THe cost of the hook ups and software was $350, but claims to do a dyno of your engine right there and eliminates the use of a dyno machine.
Any thoughts?
Any thoughts?
Moderator Alumnus
yes, its fairly accurate if it's the one which monitors RPM and you dial in the weight of your vehicle.
Here's the older version of it. I assume this new one uses ODB-II to get the readings instead of the inductive pickup.
Keep in mind you *have* to weigh your car. Can't guess, or these devices are not accurate.
http://www.charm.net/~mchaney/homedyno/dynokit.htm
Originally posted by civic4982
raptorlCLS: what's the comptuer one you were talking about?
Whether your street machine is an import or domestic, if it’s a 1996 or newer you can dyno the motor right in the palm of your hand. With Noxology’s PDA-DYNO you can measure horsepower, torque, zero to sixty times, fuel economy and drag strip performance. Using their adapter, you just connect your personal organizer into the diagnostic port of your car’s computer, and the information will be displayed on your LCD screen.
Phone: 800-NOLOGY1
URL: http://www.nology.com
mada51589
05-03-2022 08:54 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
ahsm
09-09-2015 08:35 AM
