Dyno with AEM intake and headers....
Old Mar 10, 2001 | 07:07 PM
WebToker's Avatar
This is JSuppi's dyno he just asked me to post it for him...
2001 Acura 3.2 CL Type-S
Comptech Springs
Apexi V-AFC
AEM CAI
[This message has been edited by WebToker (edited 03-10-2001).]
Old Mar 10, 2001 | 07:11 PM
astro's Avatar
Community Architect
robb m.
Wow, that's impressive...Well done John...
I'll post mine next week when I get the V-AFC installed and tuned
Astroboy out...
2001 Acura CL Type S: Comptech: Headers, filter, sways, springs, koni shocks, goodridge braided brake lines, full kicker system
1996 Porsche 911 Twin Turbo: H&R Springs and sways, Bilstein shocks
Old Mar 10, 2001 | 07:42 PM
Mike's Avatar
Cool! Jon did you reset the ecu before the dyno?
2001 Satin Silver Cl Type S.
Comptech:Headers, Springs & Sways
AEM CAI
Muds
Wheel locks
35% Llumar metallic tint
My Car
Old Mar 10, 2001 | 08:19 PM
Xephyr2K's Avatar
Reseting the ECU should b done approx. 100 miles on the car after the upgrade and before the Dyno. If you reset while at the dyno your fuel mappings etc.. will not be in an optimal callibration and will actually give you lower readings then you would see if the car has a chance to adjust. If these runs were done with an ECU reset at the Dyno you should expect them to be a bit better with a proper ECU learning cycle ! Great results BTW ! Its also great to see everyone posting the cold facts too !
Chris
2001 Nighthawk Black CLS Type S - Xephyr Performance CAI, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, 1/4 Mile in 14.424@97.23 MPH Atco Raceway Best GTECH Sprint 6.05 Xephyr Performance Intakes
Old Mar 10, 2001 | 08:46 PM
so cal type s_RENAMED's Avatar
hp seems low? didn't mike dyno with only headers get 229?
'01 cl-s blk/blk :: comptech headers, comptech springs, comptech sway bars
Old Mar 10, 2001 | 09:16 PM
Xephyr2K's Avatar
<font face="Verdana, Arial" size="2">Originally posted by so cal type s:
</font>
There are a lot of variables to take into consideration when comparing Dyno results for the same model vehicle. Some of which include Temperature, Humidity, Elevation above sea-level, barometric pressure, tire inflation, etc.... It is really difficult to compare unless there is a gaping and huge difference in the results. Even the same car on different day may show +/- 5-10 HP depending on the conditions. The only thing that seems a little odd is that the Dyno above show STD Horsepower(old correction standard rather then SAE Horsepower new accepted correction standard. Not that it is a big issue but generally STD corrected values yield better performance results the SAE correction. I believe the NHRA has deemed SAE (Society of Automotive Engineers) the industry accepted standard correction. But with so many extenuating circumstances when you Dyno test a car (Even the Dyno model) takes a toll on the event.... bear in mind folks Dyno tests are more to determine max. stock output at the crank by manufacturers and overall performance gains at the wheels by enthusiasts once a stock baseline Dyno is accepted. I think the results shown above are great and are right in the tolerences accepted by all of us .. that being 198HP at the wheels all stock ... and approx 28-30 HP increase with headers. So the figures ranging from 225-230HP are more the respectable numbers ! Withregard to the addition of the intake and not being able to see an extra 10HP in the dyno... well my own experience can attest that w/o a true simulation of airflow (the way it would flow if you were driving) the results and numbers are difficult to show. Additionally, it is not always the case that all mods result in a serial HP increase ... Stock 198 + Headers 30 + CAI 10 will not necessarily yield 238HP at the weels unless all details and operating variations are optimal... Only way to really be able to get decent reproducable numbers is with the same car, same driver, same configuration at the same track on identical track conditions... Pretty tough to get all them aligned All in all, Dyno's are great, 1/4 mile slips are better, but the bottom line how the car feels and performs on a day to day basis for you ... and if you are pleased with it
Christopher Koncur
Xephyr Performance, LLC.
Old Mar 10, 2001 | 09:31 PM
NOVAwhiteTypeS's Avatar
Which is which??? Which was his last mod??? intake or headers?? what mods where for red and what mods where for blue??
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs. Polarg m-6.
Comptech Headers, Comptech Sways, Eurolite Xenon Crystal high beams.
AEM CAI once they decide to make the dame thing.
235/40/17's or 225/45/17's once I found out which one works for me.
gtech 0-60 6.03 w/ 438 pound load. preheader.
Old Mar 10, 2001 | 09:34 PM
Xephyr2K's Avatar
<font face="Verdana, Arial" size="2">Originally posted by NOVAwhiteTypeS:
</font>
Nova:
I cant speak for JSuppi/WebToker but I believe that all four runs were with headers and AEM CAI.
Chris
Old Mar 11, 2001 | 06:01 AM
JSuppi's Avatar
<font face="Verdana, Arial" size="2">Originally posted by WebToker:
</font>
Calvin,
Thanks for postng that; too clear up the confusion. The top graph is the combination of the runs before the CAI was installed (blue graph), in this configuration it was only Comptech headers & Comptech filter. The red graph is the CAI installed w/ the Comptech headers. There is basically a +5hp throughout the whole range, and from what I can tell the torque increased throughout the band as well (didn't drop at any point that I can see).
The bottom dyno graph is basically the two best runs before the CAI was installed (headers and Comptech filter only). I was pretty satisfied with the results.
01'
Black/Ebony CLS
Old Mar 11, 2001 | 06:09 AM
Xephyr2K's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JSuppi:
</font>
JSuppi:
Great results ! Do you recall what the temp. was approximately during the tests? Also did they have a decent fan on your car to try and keep it cool and maintain airflow? If they did not have a decent fan, your results may be lower then they can be optimally with good airflow and temp Great info ! Nice runs too !
Chris
Old Mar 11, 2001 | 01:45 PM
JSuppi's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Xephyr2K:
JSuppi:
Chris
</font>
Chris,
They had some jumbo fans blowing on the sucker when I watched the first Dyno session, I was busy the second dyno session so didn't see what they did that one.
Temperature was mid to upper 70's, and of course you've got the Houston humidity coming into play as well.
01'
Black/Ebony CLS
Old Mar 12, 2001 | 08:27 AM
ChrisK_RENAMED's Avatar
Man, I envy you guys who have headers for your car. Truthfully though, do you guys think the headers are the single best modificationn you can do to the engine? I mean for the basic bolt ons, not engine work.
Chris K.
Old Mar 12, 2001 | 11:46 AM
<font face="Verdana, Arial" size="2">Originally posted by ChrisK:
</font>
One work YES!!!! worth every little friggen penny.
CL-S
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
rangomango
California
Sep 24, 2015 05:47 PM
