DRY ICE intake system..link inside
5th Gear
Originally Posted by Red-CL
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
You guys already have an "icebox" right under your nose.
It's called the Comptech Icebox. The box part is intended for dry ice.
If you put DRY ICE in a CT Ice box, the filter will suck in the melting CO2 wich will hurt combustion drastically causing a loss in performance.
The filter above just cools the pipe with dry ice, it's not ingesting CO2.
I need FI
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Originally Posted by joedokes28
I think your wrong.
Look out ladies
Kinda funny frequently asked questions....10lbs of dry ice that will last for 5 days in the trunk..
1. Q: Where can I buy dry ice?
DRY ICE CAN BE PURCHASED AT YOUR LOCAL SUPERMARKET - IT IS VERY EASY AND
INEXPENSIVE TO PURCHASE. PLEASE DO NOT HANDLE THE DRY ICE WITHOUT GLOVES.
2. Q: How long would it last?
WE HAVE TESTED THE DIIS IN HOT RACE TRACK CONDITIONS IN THE SUMMER TIME, THE
ICE IS SEALED IN AN INSULATED CONTAINMENT UNIT - ONE FULL LOAD WILL LAST
ABOUT 1.5 - 2.0 HOURS - WE ARE ALSO DEVELOPING A CARBON FIBER INSULATED
COOLER WHICH MOUNTS IN THE TRUNK OF YOUR VEHICLE TO STORE AN ADDITIONAL 10
POUNDS OF DRY ICE FOR UP TO 5 DAYS IN THE SUMMER TIME.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
I NEED MONEY!
yeh, so pretty much its a waste of money! stick to your COMPTECH ICEBOX!! who the hell is going to go to the supermarket in the middle of a race and get some dry ice...?
Originally Posted by jtkz13
Correct me if I'm wrong, but isnt that about the hp gain from a regular intake? Sounds gimmicky to me. ![Lame](https://acurazine.com/forums/images/smilies/lame.gif)
Its a bit odd that they have dyno sheets and dry ice in the intake ect.. but do not show a picture of a functioning system installed in a car .
![Fluffy](https://acurazine.com/forums/images/smilies/fluffy.gif)
Have used dry ice for long term cooling on camping or driving trips, and have yet to find it at a grocery store... have to go to an ice company... Finding an ice company could be an issue, depending on day of the week, time of day, etc... Can't see a compelling reason to buy it...
Cheers!
Jim
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![No](https://acurazine.com/forums/images/smilies/no.gif)
Cheers!
Jim
Where is my super sauce?
I've heard of people packing dry ice on their intercooler before a drag race on intercooled turbocharged engines.
For N/A I would think their is a limit as to how much benefit one would get from a cold intake. Who knows, on a hot day, it may make a minor difference in HP.
I think your wrong.
but the 4 hp gain isn't that worth it.
But it's more hp/$ than the comptech axle back exhaust which most people only see a 2-3 hp gain and that costs $669
so do the math.... let's assume you get a 3hp gain from the standalone co2 unit.
comptech exhaust gives you about $223/hp
co2 standalone unit intake gives you about $65/hp
now, the co2 unit is something i WOULDN'T do. But IF the gains are legitimate. then it's a cheaper mod than the exhaust for hp gains.
but the exhaust is cooler and sounds better
That's Racist
I want the dry ice tank (box) in the trunk. Just so I can say taht I've had dry ice in my trunk for 5 days. Then I can throw it at people.
'Big Daddy Diggler'
like with any intake, some cars see more gains than others. So maybe a turbo app can benefit from this more, not to make more power, but to maintain a cool intake charge reducing heat soak in the manifold that can cause detonation.
Doin' da crack shuffle
I think your wrong.
You're right. My mistake.
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
I was thinking about regular ice.
My dad used to run at the track and told me that they used to do this all the time (with their home made set-ups). But they used regular ice blocks and a moisture barrier.
Registered Douchebag
can someone explain to me why wouldn't water condensate inside of the pipe...??
i just know the throttle body love to sup up large amounts of H2O :wtf:
Received 1,080 Likes
I'm wondering how 'sealed' the box is. Reason I ask is, after the dry ice melts and turns to a gas, it will expand. That sealed box will turn into a bomb, so to speak. Be careful taking that top off. I'm sure it would be vented somehow, though.
A lab I interned at had dry ice along with a few classes during college. Take some dry ice and put it into a plastic container with some water...BOOM!!
AZ O.G NoOldManVetteOwner
Air passes so quickly through an intake....do you really think that little chamber is going to significantly cool any air being sucked in?
I didn't see any mention of heat transfer elements inside the pipe. If just flat walled tubing is used inside that chamber, there will be little effect at WOT. The air passing through at WOT will be above 250 inches per second. Without some elements there will hardly be any heat transfer in the roughly 50 milliseconds the air is in the tube.
LOL, I love that carbon fiber dry ice cooler for the trunk. I cant believe what some people will do for $$$.....better yet, how many people will fall for it
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Mine is to cool the water to reduce charge temps. I should be able to get the charge temps well below ambient or about 30 - 40 degrees cooler than with just the water circulating normally.
Considering this is forced induction you could expect about 2% per ten degrees drop so upwards of 6% - 8%. Even at 6% on my car that would be about 22 WHP; or almost 30 WHP at 8%. With some more boost and 103 octane, 400 WHP should be easily surpassed.
SidhuSaaB
05-30-2020 12:40 AM
rcs86
08-02-2016 06:52 PM
